  • Page:
  • 1
  • 2
Kawasaki KZ 1000 shim tool 23 Feb 2016 07:06 #712091
  • WILLIAM PIPPEN
  • WILLIAM PIPPEN's Avatar Topic Author
  • Thank you received: 0
Help
I bought the Kawasaki shim tool and don`t understand how to use it on the intake side. Once the bucket is pushed down and the tool installed, you need to roll the cam lobe up so that you can get the shim out. The cam lobe then runs into the tool at the same time it`s pressing down on the bucket. I have been taught to NEVER rotate the crank / cams backward. But that looks like the only way to make this work.
On the exhaust side, the lobe rotates away from the tool and all is well.
What am I doing wrong?
Kawasaki KZ 1000 shim tool 23 Feb 2016 08:09 #712102
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2610
You'll have to back it up a little. I had one of those years ago until someone else needed it more than me. :angry: Been stuck with the bat wing since. I hate it. I'll get one eventually. :whistle:
Kawasaki KZ 1000 shim tool 23 Feb 2016 10:33 #712133
  • jakedude
  • jakedude's Avatar
  • Thank you received: 30
WILLIAM PIPPEN wrote: Help
Does your tool look like this?
Nothing lasts, nothing is finished, and nothing is perfect.
Kawasaki KZ 1000 shim tool 23 Feb 2016 10:39 #712135
  • SWest
  • SWest's Avatar
  • 10 22 2014
$50 OUCH. It was $50 in the 70's. :dry:
Kawasaki KZ 1000 shim tool 23 Feb 2016 21:18 #712245
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
Ive always just used a bent screw driver and a home made metal wedge,But hey Im cheap! :woohoo:
Kawasaki KZ 1000 shim tool 23 Feb 2016 23:22 #712251
  • Kapahulu
  • Kapahulu's Avatar
  • Thank you received: 44
Zip ties work for me, I guess I'm cheaper than Plummen.
2strokeworld.com
Kawasaki KZ 1000 shim tool 24 Feb 2016 02:00 #712256
  • OnkelB
  • OnkelB's Avatar
  • Thank you received: 80
... I have been taught to NEVER rotate the crank / cams backward. But that looks like the only way to make this work.
It's not a problem to rotate the KZ engines backwards, as you say that's the only way to use the factory tool. You will also have to rotate the engine backwards on the exhaust side as you need to depress the bucket after replacing the shim in order to remove the tool.
I have done this several times with no issues, just remember easy does it.
77 KZ 650 B1, 82 GPz 1100 B2.
Kawasaki KZ 1000 shim tool 24 Feb 2016 06:11 #712272
  • Rockranch
  • Rockranch's Avatar
  • Thank you received: 23
$50 bucks sounds cheap after seeing these 2 lmao, and $8 for the bat. ..................................Mike
Vroom-vroom!!!
www.z1enterprises.com/product/ZSM001-113
www.z1enterprises.com/product/57001-113
www.z1enterprises.com/product/TU15-0468
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
Kawasaki KZ 1000 shim tool 24 Feb 2016 06:24 #712276
  • SWest
  • SWest's Avatar
  • 10 22 2014
The bat wing is a PITA
I had a bent screw driver and a cut and bent spoon. Worked better than that POS.
I'll bight the bullet and buy a REAL one soon. :angry:
Kawasaki KZ 1000 shim tool 24 Feb 2016 07:35 #712297
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2671
Kapahulu wrote: Zip ties work for me, I guess I'm cheaper than Plummen.
Lots of guys on the GS Resources swear by the zip tie method. Personally I use the tool but it's hard to argue with success.
members.dslextreme.com/users/bikecliff/i...lve_tool_zip_tie.pdf
Kawasaki KZ 1000 shim tool 24 Feb 2016 07:56 #712304
  • redhawk4
  • redhawk4's Avatar
  • Thank you received: 64
I don't think there's a problem turning any motor backwards by hand, the reason for turning it in the direction it runs in is to ensure any slack is in the position it would be in when the engine is running, For example setting the timing on bikes where the points run off the cam, if you set the timing rotating the engine backwards, then when going forward the timing would be out due to the play in timing chain, similarly with a distributor any backlash in the gears would have a similar effect.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Kawasaki KZ 1000 shim tool 24 Feb 2016 09:23 #712315
  • SWest
  • SWest's Avatar
  • 10 22 2014
As long as the cam chain adjuster is working properly and there isn't too much slack in the chain.
  • Page:
  • 1
  • 2
