JIS screwdrivers 05 May 2015 18:12 #670804
  • TexasKZ
  • TexasKZ's Avatar Topic Author
  • Thank you received: 2051
As 650Ed has so often pointed out, a Phillips screwdriver will too often wreck the head of a JIS screw. Here is a refresher.
www.vesseltools.com/hand-tools/screwdriv...ew-all-products.html
Here is a source for the correct screwdrivers . (Links shamelessly taken from the ZRXOA)
www.themechanicstoolbox.com/hozan-4-piec...ips-screwdriver-set/
JIS screwdrivers 05 May 2015 18:30 #670806
  • Thank you received: 2828
Here are some more. Notice the group on the right hand side of page includes #1; #2; and #3 sizes. Ed
www.mcmaster.com/#jis-%28japanese-indust...screwdrivers/=x206ws
JIS screwdrivers 09 May 2015 10:50 #671248
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
  • Thank you received: 23
If you could only have one, for working on the engine, which size would be best?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
JIS screwdrivers 09 May 2015 13:12 #671259
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
  • Thank you received: 300
#2...unless I had converted to allen heads for the bulk of the motor screws :)
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
JIS screwdrivers 09 May 2015 14:08 #671264
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
A #3 is what you need for the starter clutch and engine covers ........ I saw a JIS Vessel on Amazon that is a impact and screwdriver combo ...... on Ebay too but a little higher.... gotta admit I cheated for now though and used my sears impact and a reg #3 bit that fitted better than the couple of reg #3 drivers I have.
Converted to mostly all allen heads a long time ago so I'm being cheap and worked with what I have.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
JIS screwdrivers 09 May 2015 16:03 #671274
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Last edit: by 650ed.
JIS screwdrivers 09 May 2015 18:06 #671286
  • TexasKZ
I have done just what 650Ed shows, and it works wel.
JIS screwdrivers 14 May 2015 16:02 #672132
  • Randombeat
I just got one of these off fleabag, 17$, #3 jis tip. They are available in #1 & #2 also, build quality is awesome.
Attachment vessel-megadora-980-impacta-p2x100-2-cross-point-impact-screwdriver-4.jpg not found
JIS screwdrivers 14 May 2015 17:38 #672142
Yes indeed - Vessel makes quality screwdrivers. Ed
JIS screwdrivers 14 May 2015 21:30 #672184
  • ezrider714
  • ezrider714's Avatar
  • Thank you received: 38
Much simpler and nicer looking to just change out to SHCS's :cheer:
The heads of stock screws also strip out due to the inferior quality of steel used back in the 70's :unsure: regardless of screwdriver tip used.... :ohmy: .
To each their own :)
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
JIS screwdrivers 15 May 2015 03:56 #672196
ezrider714 wrote: The heads of stock screws also strip out due to the inferior quality of steel used back in the 70's :unsure: regardless of screwdriver tip used.... :ohmy: .
Since learning about JIS drivers I have never had any damage to the stock screws. Some of them had never been removed in more than 30 years and were stubborn, but unlike Phillips screws they simply don't deform if the correct tip is used along with a little Kroil when necessary. Personally, I'm no fan of the allen type screws, but that is mainly because they were on the BSA I had and the previous owner had stripped out many of the threads in the engine :angry: I'm sure if they had not been over-torqued they would have been fine. As you say - to each his own. Ed
JIS screwdrivers 15 May 2015 05:21 #672197
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
RJR is probably a small potatoes operation, so before ordering anything, ask if the desired tools are in stock. Otherwise, the guy will send a partial order, but the invoice will not reflect the missing tools & you will not receive an email indicating that the order is incomplete --- then hope he sends the missing stuff. Good luck getting timely replies to emails. Needless to say, I wouldn't buy anything from RJR again.
