Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 15:07 #486294
  • clutch
  • clutch's Avatar Topic Author
  • I wish I had a tad more patience to do it better!
  • Thank you received: 12
I'm thinking jb weld will hold up against gas (and ethanol :sick:). I don't mind making a permanent bond on the plate itself. It definitely would be a pain to get tha stuff into the threaded area, but at this point I want to fix it and forget it. If I have to clean up a little squeeze out quickly with a rag, I will. If it will work, I think it's worth the extra effort to make sure it's cleaned up in there :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 15:09 #486295
  • clutch
This is from the JB Weld website:
"Q: Is J-B Weld resistant to water and/or gasoline?
A: When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical. For wet-surface or submerged water or gasoline repairs, see our J-B Stik or Waterweld product information. "
Wish List:
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 16:27 #486315
  • clutch
Just found a bunch of posts on a ifferent forum, with people saying the ethanol gasoline eats through jb weld. :huh:
Wish List:
Z1 (need I...
Last edit: by clutch.
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 16:29 #486317
  • clutch
From Wikipedia:
About alcohol
The JB Weld company advises "DO NOT" use alcohol to clean surfaces.[3] Denatured alcohol (ethanol) acts as a thinner for J-B WELD or epoxy, so it drips more or runs into cracks.[1] However, rubbing alcohol (isopropanol and water) should be avoided as a thinner, because of the larger proportions of water.[1]
Wish List:
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 16:38 #486322
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
i can tell u from experiance that JB Weld is NOT gas proof, when submerged. i have tried to use it to repair carb parts and it fails.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 16:40 #486323
  • clutch
ANyone know if neoprene gasket material will hold up against the deathanol?
Wish List:
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 16:49 #486325
  • clutch
clutch wrote: ANyone know if neoprene gasket material will hold up against the deathanol?
Nope....
I wonder if my buddy that welds could seal it up for me???
Wish List:
Z1 (need I...
- 31 Oct 2011 17:59 #486333
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Last edit: by martin_csr.
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 18:01 #486336
  • clutch
Yes. I already have the parts, yet I'm having issues with leakage. I don't want to go back to the vacuum petcock if I can stop the leak.
Wish List:
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 18:13 #486337
  • clutch
I've been searching the web for hours, and so far this is the best thing I've found for info...
iqlearningsystems.com/ethanol/downloads/...%20Compatibility.pdf
Wish List:
Z1 (need I...
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 18:14 #486338
  • Thank you received: 2829
You shouldn't need any sealer on the gas tank; what are you trying to seal? The petcock (at least on mine) uses an oval rubber O-ring that prevents any leaks. Did you do some homemade mods to the tank? Ed
Permatex No 1 Gasket Maker is CRAP! 31 Oct 2011 18:42 #486339
  • Motor Head
  • Motor Head's Avatar
  • Thank you received: 391
You got one of those Pingel Adapter plates that is flat with the 2 bolts and gasket, right?
So which joint is the problem, plate to tank or petcock to adapter?
