PLUMMEN wrote:
To protect the enviroment in which we al live,Kawasaki has incorporated two emission control systems in compliance with the applicable regulations of United States Enviromental Protection Agency.
Because the adjustments to these highly complex systems are crucial to protecting the global ice caps, the adjustment mechanisms are sealed with 2.5kg of JBWeld. Only qualified personnel should attempt to remove the sealant. If you are qualified, be sure to wear the appropriate HASMAT suit and be certain to dispose of the residue according to CARB and EPA guidelines.
The only owner-serviceable part of the emissions system is the reed-induction piston redacter. Once every 31,437.3 km or four days, whichever comes first, replace the 17.803 litres of fluid and the fluid filter. Use only genuwine WD39 and a made-for-Kawasaki Fram filter.
However, if the motorcylce diplaces less than 1000cc or has fewer than four cylinders, toss a lighted match in the fuel tank and run like you are chasing naked blondes.
