Torque Wrench? 21 Dec 2010 00:52 #417997
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
  • Thank you received: 36
Pardon my absentmindedness, I lost you with the thread chasing bolt?
Do you cross-thread the bolt on?!?
Or do you take a Dremel and cut the threads (4 or so) on the threads of the bolt?
2000 ZRX 1100
1976 KZ 900- Daily Driver
Torque Wrench? 21 Dec 2010 21:25 #418163
  • crusty shaftie
  • crusty shaftie's Avatar
  • Thank you received: 0
Becker is absolutely right! Lubricate your fastener before installation, use motor oil at the bare minimum, the better would be moly and the best would have to be an auto cam break-in lube many companies offer it Comp, Crane, ARP ect. It has a higher lubricity than oil and WAY better than nothing. When learning on a dead motor my instructor showed us the differance @75lbs/ft they all speced out different when re-checked.
Torque Wrench? 26 Dec 2010 22:30 #418752
  • Dragone
  • Dragone's Avatar
I agree with chasing threads to make sure they are clean, etc. But you risk of over torquing if you lube up the bolts. The cheap bolts will stretch no matter what, the grade 8+ may be over tightened and cause structural/case or whatever damage from over tightening because of the lubricant. Just my experience.
edit: I use 3 clickers from craftsmen to snap on, the best is still the beam for tight tolerance for me.
Last edit: by Dragone.
Torque Wrench? 26 Dec 2010 23:02 #418754
  • stonemaster
  • stonemaster's Avatar
  • Visitor
I have read lubricating changes the target torque value, I'll try to find the article. anyone else on this ???
Torque Wrench? 27 Dec 2010 06:55 #418776
  • jjdwoodman
  • jjdwoodman's Avatar
  • Live free, or die.
  • Thank you received: 1
SM
Yes, my friend, lubing the threads will give you different results. The kicker here, is some torque values are given assuming lubed threads, while others state specifically to install the bolts dry.
My experience has been that most of the two or three step torque sequences using progressive torque values only use lubed threads, while the torque sequences using the thread stretch method use only dry new head bolts. (sorry forgot to mention this applies only to heads as far as I know)
I believe all these old bikes use the lubed torque method, but you should always verify all the torque specs with the service manual to be sure.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
Torque Wrench? 27 Dec 2010 07:59 #418779
  • stonemaster
  • Visitor
jjdwoodman wrote:
SM
yea the article I read ( and it was a long time ago) mention some of that as well,personally I only clean threads but lube when instructions say, but havent ran into that yet, even on a head,
Torque Wrench? 27 Dec 2010 08:02 #418781
  • stonemaster
  • Visitor
here's a poor mans method of checking torque wrench accuracy, someone told me about this awhile back but here it is copied from a post from another site
How to perform your own torque wrench calibration testing
It doesn’t make much sense to take an inexpensive consumer grade torque wrench to a metrology lab for testing. The cost of the wrench just doesn’t justify the expense. But you have to know how accurate your wrenches are to have any confidence in your work.
Fortunately, it is actually quite easy to verify accuracy right on your own work bench at home. And your results can be just as accurate as anything done in a lab.
How to Calibrate a Torque Wrench
Tools needed:
1. A heavy duty vise and a sturdy work bench. The size and quality of the vise will depend on how high your torque wrench reads. A ½” 250 lb.ft. torque wrench will need a heavy duty vise with strong jaws. It will also require that the vise be mounted to a sturdy work surface.
2.Weights. I used pieces of bar steel, but barbell weights are perfect. The exact weight doesn’t matter. What does matter is getting weights that will allow you to test the wrench in the normal range that you use it. You can test at only one weight, but if you want to check consistency, get 2 or 3 of them and stack them. As a general guide, if you have a 3/8” and 1/2” wrench like I do, weights in the range of 20 to 55 lbs will suffice.
3.String or bailing wire to hang the weights from the torque wrench.
4.A method to weigh your weights. Stop by your local UPS store or the post office as ask them if they can weigh them for you. Don’t rely on a bathroom scale. They are too inaccurate and you will just be wasting your time. If you permanently mark the numbers on the weights, this is the only time you will ever have to do it.
I need to point out here that weights should be chosen to give you measurements that are in the heart of the tool’s adjustment range, or the range that you normally use it. Don’t use a 20lb weight on a 250 ft.lb. wrench. Not only should you never measure torque in this range with this size wrench, but the wrench will be very inacurrate in that lower 10% range. I found that my 250 lb.ft. wrench was off by 25% at 27 lb.ft.
Procedure:
1. Mount the square drive of the wrench in a vice. It should be oriented so that the handle pivots vertically. (Use the side of the vise jaws.) Set the handle in a position as close to parallel with the ground as possible. Also make certain that the wrench is set for tightening, not loosening.
2. Devise a method for hanging your weights from the string. If you are using barbells, you can run a large eyelet bolt through the middle and use large fender washers. Tie a loop in the top of the string.
4. Wrap your hand around the handle where you normally grab it and mark the center point. Usually the middle finger or just to the right, between the middle finger and ring finger is close. You can also use the center of the grip as a calibration point. The reasons are explained at the end of this procedure.
5. Hang the weight from the handle where you marked it. (If you have a soft, cushioned grip, protect it with something like a thin piece of rubber.) Here is a picture of what everything should look like.
6. Start adjusting the torque until the handle clicks. If it clicks right away, lift the weights and back off on the setting. Keep going back and forth with the adjustment until you find the setting where it just barely clicks. Every time the wrench clicks you will have to lift your weights to reset it.
7. When you find the transition point between clicking and not clicking, make note of the setting the wrench clicks and write it down.
8. While you are at it, grab a tape measure and measure the distance from the point where the string hangs from the handle to the exact center point of the square drive. If you have a typical wrench with a direction dial on the back, you can usually measure to the midpoint of the dial if it is directly behind the square drive. The more accurate you are with this measurement, the more accurate the results will be. Nearest 1/8” is ok. Convert any fractional measurements to decimal. As an example, 15 5/8” would become 15.63”
9. You will now do this simple calculation; This is a very simple concept. Torque = weight x length. As an example, if you hang 20 lbs exactly one foot from the fulcrum, the torque would be 20 lb.ft. If you went 2 ft. away it would be 40 lb.ft.
Perform the calculation. Multiply the weight of your test weight by the distance you measured and divide by 12 (to convert inches to feet). If you are testing an in.lb. wrench, don’t divide by 12.
The result of your calculation is the actual torque being applied by the weights. Compare it to the setting on the torque wrench and you will have the amount of error. In other words, if your wrench is set to 42 lbs, and the measured torque is 38 lb.ft., the wrench is off by 4 lbs, or 10%. (That’s pretty bad)
An important characteristic of any torque wrench is repeatability. Check the transition point between no click and click numerous times to make sure measurements are repeatable. In this way you can gauge how trustworthy your measurements are. Even the cheapest wrenches should pass this test within 1 lb.ft. or so.
These days, most consumer grade torque wrenches under $75 no longer have a means to align them. If they do, there will be a hole in the handle somewhere with an alignment screw. If there isn’t one, just apply a correction factor into your measurements when adjusting the setting. If the wrench is off by a lot, you are probably better off just getting a new wrench.
I have a 35 year old TRW 1/2" and a 10 year old Craftsman 3/8". Here is what I came up with.
My Test Results: (To give an example)
TRW ½”
37lb x 15.3” = 566.10 /12 = 47.18 lb.ft.
With my TRW and 37 lbs, my calculated torque was 47.18, indicated was 48. I still need to come up with a weight of about 55 lbs to accurately measure the wrench at 80 lb.ft. This is the setting where I normally use it. It is just amazing that a 35 year old wrench that has been dropped numerous times is still this accurate today.
Craftsman 3/8”
12.25 x 21.5 = 263.38 /12 = 21.44 (The wrench was set at 22.5)
12.25 x 37 = 453.25 /12 = 37.77 lb.ft. (The wrench was set at 39)
My inexpensive $75 Craftsman was surprisingly accurate. It was only off by 3% off. That’s pretty darn good for an inexpensive consumer torque wrench.
I hope this helps those that worry about the accuracy of their wrenches.
Last edit: by stonemaster.
Torque Wrench? 27 Dec 2010 22:07 #418849
  • mtbspeedfreak
Great thanks for all your advice guys! I don't have a vice yet, a solid homemade workbench is next on my chore list. Naturally a sturdy vice would come with that.
2000 ZRX 1100
Torque Wrench? 29 Dec 2010 01:33 #419076
  • Zedone
  • Zedone's Avatar
  • Thank you received: 14
With all due respect to purchasing "Overseas" tools and especially torque wrenches I 100% totally disagree. IMHO a high end torque wrench is one tool you shd. drop $$$ on. The last place you want to have a fastener fail is on a brake or suspension component.... let alone a crank main, cam cap, ect due to incorrect torque values. Sorry, I just don't understand the logic of using a cheap tool in critical areas. Regards, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
Torque Wrench? 01 Jan 2011 11:27 #419613
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
  • Thank you received: 28
I like a really well built tool, the price doesnt matter to me. It's either really solid and lasts (with me that usually includes getting dropped and smashed with a hammer lots) :laugh: ,or its crap.
Mid range stuff is fine... with torque wrenches we check them compared to others lying around, and send them in periodically/yearlyish to be re-calibrated and often they come back with the specs having been only a very small amount out, even on some of the cheaper ones.
The thing to remember with a torque wrench is to always unload it (drop it back to lowest setting), else it will get out of whack quick.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Torque Wrench? 02 Jan 2011 22:53 #419835
  • mtbspeedfreak
Oh, most definitely! I'd much rather have a few Snap On torque wrenches sitting in my toolchest than the Harbor Freight ones I have now.
I suppose a cheaper wrench that is off by 6% is better than my best judgement, which will likely be off by 50% in the best case scenario. :silly:
I dropped about $40 bucks for the three wrenches I bought using a combination of coupons and multiple trips to use those different coupons. The 3/8" 20-100 ft/lb Snap On wrench is guaranteed to be within 4% CW and 6% CCW... it costs $262. Only after I marry a rich woman, I'll be able to afford those.
2000 ZRX 1100
Torque Wrench? 27 Mar 2011 23:37 #440877
  • veritas.wilson
  • veritas.wilson's Avatar
kobalt also comes with a life time guarantee which isnt advertised very well. lowes's attempt to keep up with sears, and as always with lowes, its very easy to return anything there
