A true 5 hp motor will pull 21-22 amps running, more on start up.
So that's 42-44 amps running for a 10 hp, and more (much more, depending on load) on start.
Since you're talking industrial stuff then that is probably the real hp rating and not the inflated numbers used in consumer stuff.
15 hp will probably pull 60-66 Full Load Amps (FLA on the data plate). Full Load Amps is the amp draw at max load, at lesser loads the amp draw will be less.
A clamp on ammeter will reveal the truth
I have 200 amp service with garage and house both on 100 amp breakers, and separate service panel in garage with it's own ground. No problems with light dimming or anything else so far.
