  • Page:
  • 1
  • 2
Common hand-held water sprayer 12 Feb 2010 15:22 #347937
  • Patton's Avatar Topic Author
  • Thank you received: 2098
Never test heat of an exhaust header by touching it with your fingers, or any other part of your anatomy.
Instead, use a common household water spray bottle to spray water mist onto the pipe.
A properly combusting cylinder will cause the water mist to instantly sizzle and evaporate.
An improperly combusting cylinder may be merely warm and the water mist will bead and run down the pipe.
Or in a pinch, you may just spit on the pipe, or use another body fluid.
Re-read the first sentence. Or bone up on treatment of burns.
Good Luck! :)
Last edit: by Patton.
Common hand-held water sprayer 12 Feb 2010 18:00 #347953
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
how did you learn not to use parts of your body? :laugh: a wet sponge is a little easier to control if you have one B)
Common hand-held water sprayer 12 Feb 2010 19:23 #347965
PLUMMEN wrote:
... a wet sponge is a little easier to control if you have one B)
Common hand-held water sprayer 12 Feb 2010 19:30 #347967
  • trianglelaguna
  • trianglelaguna's Avatar
  • Thank you received: 235
i use my hand to push down on the oven burners and get em more level....i do really...it's just healing now......
exhaust ??what idiot would do that
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Common hand-held water sprayer 12 Feb 2010 19:55 #347969
  • PLUMMEN
  • PLUMMEN's Avatar
Patton wrote:
my point exactly! :woohoo:
---- 13 Feb 2010 06:30 #348007
  • H1Vindicator
  • H1Vindicator's Avatar
  • Thank you received: 45
Last edit: by H1Vindicator.
Common hand-held water sprayer 13 Feb 2010 06:35 #348012
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
I use my hands as well early on while just starting up.
I have ran back to retrieve the back half of my exhaust from the highway, grabbing it with a bare hand, and getting my fingers toasted. :ohmy:
Had to ride the rest of the way to Niagra Falls (and back home) with one burnt hand (right) and open headers.
A mist bottle is a great idea. ;)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Common hand-held water sprayer 13 Feb 2010 07:37 #348024
  • Kawickrice
  • Kawickrice's Avatar
  • Thank you received: 18
I have a friend that uses a Laser Thermometer to measure everything from coffee to exhaust to cylinder walls to his toaster
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Common hand-held water sprayer 13 Feb 2010 14:17 #348086
  • gane
  • gane's Avatar
Laser is also handy for determining wort temp before pitching yeast, instant, & no need to sanitize. (home brewer)
[img][/img] 1977 KZ1000A1
Common hand-held water sprayer 18 Feb 2010 19:06 #349102
  • tooocool49723
  • tooocool49723's Avatar
  • Thank you received: 0
I just hold my hand back from it. Pretty easy to tell three hundred degrees from one hundred at an inch or so and not burn your hand lol!
Now an industrial air compressor high pressure line, watch out for those. They get damn hot without any warning!
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
Common hand-held water sprayer 25 Mar 2010 11:57 #356061
  • mwarren101
  • mwarren101's Avatar
I seem to remember my Granma telling me years ago that a hot pan looks exactly like a cold one. Of course, me being the good infantry material that I am... I have to test it every time!
Common hand-held water sprayer 25 Mar 2010 12:06 #356062
  • Russ Jackson
  • Russ Jackson's Avatar
I guess when I am driving down the road and a plug fouls I will use the spray bottle that I have strapped to my sissy bar. Instead of just tapping the exhaust....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
  • Page:
  • 1
  • 2
