  • Page:
  • 1
  • 2
temp fuel source 22 Jan 2010 05:06 #343883
  • Silverado6x6
  • Silverado6x6's Avatar
  • Thank you received: 0
When I was working on my Honda CX 500 I took some galvanized pipe bushings and made a reducer from a 8" piece of 2" pipe down to a 1/4" brass barb with a see through fuel filter, that was fine for that bike but now I need to make another that has two fuel outlets for the Z1B I'm working on, or I'll just make another of the same.
I would just hang this over the handlebar and it wouldn't give a lot of run time but it was easy to top off.
temp fuel source 14 Mar 2010 15:57 #353396
  • mtkawboy
  • mtkawboy's Avatar
  • Thank you received: 16
Old snowblower tank for you northern guys is what I use with a shutoff valve & hoses set up for 1,2,3 or 4 cylinders
temp fuel source 18 Mar 2010 07:03 #354231
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
  • Thank you received: 3
I am getting ansy and want to start up my bike, so I am going to let the paint on the tank cure and am going to try using the bottle from my lucas break in oil additive. I will rinse it out really well with some gas, and then stick the pointy spout into my fuel line, hopefully the little barbs hold in the fuel line!
Would I need to plug up the vaccum line on my BS34 carbs if I am using this temp fuel source?
Last edit: by 9am53.
temp fuel source 18 Mar 2010 09:40 #354251
  • Thank you received: 2098
Yes, vacuum should be capped.
And fuel source should be vented.
Good Fortune! :)
temp fuel source 17 Jun 2010 19:05 #376480
  • krazinite2003
  • krazinite2003's Avatar
9am53 that is what i use for my temp fuel sorce but i found that it my leak where the hose conects to the pointy end of the bottle
i have two 1983 kz750 L3
temp fuel source 17 Jun 2010 20:06 #376502
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Thank you received: 1306
Take one paint thinner can add a barbed hose fitting and a bit of solder.
This one's been feeding my projects for thirty years.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: by KZQ.
temp fuel source 19 Jun 2010 02:29 #376730
  • larrycavan
  • larrycavan's Avatar
  • Visitor
Old 2 stroke oil reservoir tanks work great for that as well. Mine hangs from the handlebars and "IT'S GENUINE KAWASAKI" so the carbs synch in more precisely :laugh:
temp fuel source 21 Jun 2010 18:48 #377404
  • stonemaster
  • stonemaster's Avatar
  • Visitor
someone needs to make one out of one of those Heineken mini kegs
  • Page:
  • 1
  • 2
