1980 kz250 LTD sitting at 90psi engine pressure. help!
- Buschpush
- Forgive me if I sound dumb, new to this
06 Jun 2024 17:34 #900390
by Buschpush
1980 kz250 LTD sitting at 90psi engine pressure. help! was created by Buschpush
So I just redid the left side, right side, top half entirely, cam gasket and many more where am I losing that much pressure?
KZ250 LTD 1980
I have the muffler off but carb on idk where I could be lossing this much pressure how do I check where I'm lossing it?
Here is a video
youtube.com/shorts/5C0SOG86yo4?si=LXATcZdqL3ZNzk1o
KZ250 LTD 1980
Here is a video
- Thank you received: 2806
06 Jun 2024 18:11 #900391
by Nessism
Replied by Nessism on topic 1980 kz250 LTD sitting at 90psi engine pressure. help!
Engine warm, throttle full open, in order to do a proper compression test. Also, the bike needs some miles on it. Not a never run top end, although even that should make more than 90 psi.
Did you verify valve clearances?
- Buschpush
06 Jun 2024 18:54 - 06 Jun 2024 20:14 #900392
by Buschpush
Replied by Buschpush on topic 1980 kz250 LTD sitting at 90psi engine pressure. help!
Yeah valve clearance checked but didn't have throttle fully open!
Update; got it to 110 psi with throttle open!
Last edit: 06 Jun 2024 20:14 by Buschpush. Reason: Update
