Solenoid clicking but not turning over what am I doing wrong I'm new to this?
- Buschpush
- Forgive me if I sound dumb, new to this
It's a 1980 kz250 LTD just put it back together after a cam shaft and gasket replacement my solenoid is clicking but not turning the starter over.
I'm new to this so forgive me if it's something really simple.
Attaching a YouTube short below
youtube.com/shorts/Qet1dS5B9vo?feature=share
- Buschpush
- Buschpush
- Thank you received: 2053
This can cause that high amps can´t feed the starter motor to turn over the engine. You can try to test connect the starter solenoid plus terminal
to the battery plus terminal with a jump wire. Please use a suitable wire cross section typ for the high amps..
- Thank you received: 2281
if I am reading this correctly - are you suggesting putting oil in the spark plug hole because you didn't lube the cam when installed ? If so DON'T DO THAT !!!!!! the oil will hydraulic the engine and potentially bend a Conrod or damage the piston. Oil put in the head when assembling doesn't find it's way into the cylinder.I should specify the battery is fully charged, should I put oil down the spark plug as I didn't load up the top half with oil before starting?!
I am going to guess you are new to this kind of thing given your oil in the plug hole question ? Before you dive into the electrics, with the spark plug removed can you turn the engine over by hand easily ? Are you sure the cam timing is correct ? Did the starter work OK before removing the head ?I can't seem to find the answer in the service manual.
What is the battery voltage when you push the starter button ?The battery is sitting at about 12volts/11.9volts
- Thank you received: 1087
Completely agree HRM (hence the voltage under load check) I have however (based on an obvious lack of experience) suggested some basic mechanical checks first to ensure correct assembly before causing any mechanical damage (probably over cautious but "who knows")It is probably your battery. Try boosting and see if the engine turns over.
- Thank you received: 2216
I think overly cautious is the way to go here. It is very easy to get the cam timing wrong, and that can end with much sadness. I, too, suspect the battree is too weak to do the job.
- Thank you received: 1655
A good battery should be at least 12.6 VDC after charging. I use a Ctek US 0.8 smart charger.
If it's 11.9 VDC after charging with a good charger, then the battery needs replacing.
The voltage may be enough to actuate the solenoid, but not enough for the starter which is a large DC motor.
I would check the voltage at the fat cables on the solenoid; especially the one that goes to the starter >> connect meter and press the start button.
Basic motorcycle starter solenoid tests. google search = how to check a motorcycle starter solenoid:
- Buschpush
Am I to take it apart and empty the oil from the piston, damn I fucked up eh
I just read up on what I did, fucking hell man
Where do I go from here? Take out the engine and get out as much as I can?
