  • Page:
  • 1
  • 2
Oil filter 14 Feb 2024 06:56 #895241
  • KZNewbie76
  • KZNewbie76's Avatar Topic Author
  • Thank you received: 2
hello I have a 1981 KZ1000 LTD and I recently purchased this oil filter off of amazon. I am wondering if I have the correct oil filter? If I do not where can I find a place that I can shop for KZ1000 parts that will give me the correct part? Have a great day and thank you in advance
Oil filter 14 Feb 2024 07:39 #895243
  • Injected
  • Injected's Avatar
  • Thank you received: 421
The Kawasaki part number for the 1981 KZ1000 LTD oil filter is #16099-003 it also fits the 1982 KZ1000 R1 and every 1000/1100 engine from 1981 to 2005 on various models.
The following user(s) said Thank You: KZNewbie76
Last edit: by Injected. Reason: sp
Oil filter 14 Feb 2024 08:38 #895245
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
Might i spoil Your day, not intending to but "Please" don't purchase that critical crap off Amazon!! Not only can the filter element be sub-par but the two rubbers will surely turn to mush. Chinese cheap shite rubber, as well as other quickly duplicated/copied, products. Fram had a disparage with the Z1 filters, and probably never rectified that issue either. I discussed that with the manufacture several years ago, resolve, never changed anything. I'd toss that POS and purchase something else. My 2-cents but pay heed, Please!
The following user(s) said Thank You: blipco, slayer61, howardhb
Oil filter 14 Feb 2024 09:45 #895247
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 258
+1 on asphalt900's reply.  Quality oil filters for your KZ are not very expensive, why take the chance on questionable chinese ones?
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Oil filter 14 Feb 2024 19:34 #895267
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1033
Make that three!
You can get OEM filters from any Kawasaki dealer, or you can order online from Partzilla.  I've used K&N in the past as well.
Oil filter 14 Feb 2024 19:44 #895268
  • sf4t7
  • sf4t7's Avatar
There are a couple of K&N's in my garage, ready for the next 2 oil changes.  I order 4 at a time.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Oil filter 15 Feb 2024 04:47 #895274
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2074
NAPA.Their line of Gold filters are good.
Webike, Partzilla, Ron Ayers and your local Kawasaki dealer carry the genuine factory filter.
Oil filter 15 Feb 2024 05:03 #895275
  • TexasKZ
  • TexasKZ's Avatar
Last edit: by TexasKZ.
Oil filter 15 Feb 2024 10:22 #895277
  • asphalt900
Always keep quality filters and plugs on hand, takes time to accumulate this much crap! But it saves from the wait from shipping to the door...
The following user(s) said Thank You: sf4t7, howardhb, Kelly E
Oil filter 15 Feb 2024 17:31 #895298
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 307
Hey I have a cabinet like that full of plugs, air and oil filters.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Oil filter 15 Feb 2024 19:01 #895303
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
While I wouldn't buy a filter like mentioned, if I already had it, I'd slam it in and ride.
Oil filter 17 Feb 2024 08:43 #895354
  • asphalt900
Yuppers, but double check the internal outside to outside dimensions of the rubbers in the filter compared to the one you'd pulled out. This is the problem with the assigned Fram part number for the Z1/KZ900/1000's I'd experienced in the past. You stand the risk of hyper-crushing the cover side spring. Also note make sure YOU still have the slim washer between mentioned spring to filter rubber gasket!! I only retain quantities because i moved from the city to a rural area, 30 mile roundtrip to get a pack of Wrigley's gum. I end up working on all my neighbors, fantastic by the way, stuff. The dangling Suzuki 3-cyl gas engine, hard to find in the wild but..
  • Page:
  • 1
  • 2
