  • Page:
  • 1
  • 2
high oil consumption 08 Dec 2023 00:03 #892451
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
WISECO pistons have a better implimentation, in my opinion, of those oil holes !
Holes are much bigger (less likely to clog with carbon), and half (cross-section) of the oil holes are ALWAYS exposed and are not totally obscured by the piston ring... clever !
I think this design improves cylinder lubrication as well !
My list of Christmass presents now includes a set of these....
Hurry up Father Christmass....
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Last edit: by howardhb.
high oil consumption 08 Dec 2023 08:06 #892463
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 139
Marvel Mystery Oil (MMO) is a good product to break down carbon on pistons.  I learned this from some GM Saturn engineers, who told me it was recommended in those cars to keep the rings free, because those cars had "low tension" rings, which liked to coke up.  I don't know the ratio of gas to MMO, but the recommendation was to add some to the gas when filling up.
Snake oil, hope for the hopeless. But I'll still give it a try.
Kind of like when I buy all those over the counter cold remidies, knowing they woun't work.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
high oil consumption 09 Dec 2023 12:33 #892489
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 125
Here is a pick of my oem kz900 piston my fj also has double set of oil holes
The following user(s) said Thank You: willemZ900, howardhb
Last edit: by Rolf1976_KZ900.
high oil consumption 10 Dec 2023 10:04 #892526
  • ckahleer
It was in the mid 60's yesterday, so I went for a 100 mile ride on the bike, after adding 2 oz of Marval Mystery oil to the fuel, as Nessism suggested. Should I also add some to the oil?
I also did some plug chops durring this ride. I'll start a plug chop thread with picks of the results.
BTW, I'm not a professional mechanic. Just self taught, out of financal, need to fix my own stuff. So there are holes in my knowlage. (like the holes in the piston groves.) The Kawasaki service manual said to clean the carbon out of the groves but made no metion of the fact there were holes that needed to be cleaned.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
high oil consumption 10 Dec 2023 10:33 #892530
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Throw some strait 50 or 60 weight oil in it! If that don't help? Last try is saw dust! Learned that from Lucky's used cars in the late 70's
I've been using Marvels since 1975! In every engine i've ran! lawn mower, snow blower, cars. My old Shovel head still has original soft valve seats made for leaded fuel! second set of valves are stainless, and I put Wiseco forged pistons in it in 1989. Have not taken it apart since.
I've told you guys here 15 years ago about Marvels 50% with mineral spirits and lacquer thinner! That is my go to miracle snake oil juice!
We hone the cylinders on our old 54 cast iron Chrysler Hemi Gasser, Supercharged on Methanol.
I've honed any Kaw block I've ever did also with Marvels! straight hones or ball hones.
Marty in Buffalo
high oil consumption 10 Dec 2023 11:44 #892535
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1863
I take it the saw dust was to stop a slipping clutch (leaking crank seal) to get it "off the lot"
  • Page:
  • 1
  • 2
