'79 KZ400 Crankshaft oilway plug thread question
- adam73bgt
29 Oct 2023 16:12
Hi all, got a bit of an odd one.. I've been rebuilding my KZ400 engine, it was a non-runner when I bought it and after getting it all stripped down found loads of oil sludge in the crankcases, so I've been cleaning everything up for reassembly.
I had a local machine shop remove the screw in plugs from the crankshaft to be sure that all the oilways within were clear of any sludge. These plugs
All cleared out no problem, I bought new plugs to go in. The issue was that the threads appeared a little damaged from when the plugs were removed so the crank went back to the machine shop and they tapped them.
The plugs thread in fine, but they can screw further down into the hole than before, I would have thought the plugs should be tight but still flush with the top of the hole so that they can be staked?
Has anyone else had these out before and can confirm? Trying to work out what my best option is, I don't want them to work their way out once the engine is running!
1979 KZ400 B2
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
2003 Chrysler Crossfire
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
Re: '79 KZ400 Crankshaft oilway plug thread question
29 Oct 2023 16:58
Being flush at the top is much less important than them going in too deep and causing an obstruction in the oilway. Does the new thread stop short of the bottom of the hole? As long as the screw doesn't protrude down into the oil passage you can screw in tight and deform with a sharp punch to hold them in place
- adam73bgt
30 Oct 2023 09:16
I'll have to double check, I'm pretty sure it did stop short of blocking off the oil passage but it was threading in so far I wound it back out till it was flush and staked it. Then thought about it a bit more and figured that might not be an ideal solution.
The plugs will need to come back out anyway I expect. My other thought was if it's quite far down in the threads, it'll be tricky to get the punch in to stake it properly
1979 KZ400 B2
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
30 Oct 2023 09:19
If the plug isn't screwed in tight you may lose oil pressure at the crank bearings ?
- adam73bgt
30 Oct 2023 16:11
Yeah that was my worry as well..
Well I got one of the plugs back out and screwed it in until it went tight, can see how far it sits down the threads now. It's not showing anything blocking off the actual oilway though so I don't think it would be having any effect on oil flow to the bearings
1979 KZ400 B2
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
30 Oct 2023 19:06Please please please, click "insert all" when posting photos. That way the photos show up in real size, not tiny thumbnails.Yeah that was my worry as well..
- adam73bgt
31 Oct 2023 02:04
1979 KZ400 B2
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
4 Wheeled Projects:
1973 MG BGT
2000 Alfa Romeo 166
31 Oct 2023 04:34
Just to be clear (your picture showed the passage is clear at the journal) if you look at the below where the blue arrow is, the black line is the oil passage through the crank which you need to be careful you don't restrict with the plug being in too deep
