Help needed with Pipe Exhaust for Z750 L2 29 Sep 2023 23:35 #889908
  • thanos12
  • thanos12's Avatar Topic Author
  • Thank you received: 0
Can anyone provide the part number of #3 (Right) Exhaust Pipe for my Z750 L2 ? I have lost the manual :(
Probably would start with 18049-
I know that the L3 and L4 model have the same part number 18049-1163.
Does anyone has the part manual from L2 to verify it?
Thanks in advance!
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 05:43 #889913
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
L2-L4 should be the same.  Also, same as R1, only that exhaust is black.
And regarding the inner headers for #2 & #3, it seems that they are all the same across all the KZ750/4 family of bikes.  That should help you expand your search.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 10:38 #889925
  • thanos12
The L3-L4 have printed mark E005 concerning the emissions. The L2 has E004. So I would like to confirm from someone who has the manual within his hands. Thanks for replying.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:13 #889927
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 373
I do not have a manual for the L2, but do have this link for parts list for the L3. Not sure if it will provide any help or not but here it is.
kz.bike-night.com/parts/C-10Mufflers.jpg
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:27 #889930
  • thanos12
Thanks for the info again but I need it from L2 manual. Look also the differences (image attached).
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:27 #889931
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Cmsnl.com in the UK may have diagrams for your motorcycle with part numbers.  But there won't be any emissions info.
Last edit: by martin_csr.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:29 #889932
  • thanos12
They do NOT have for L2. I have already searched. Generally my question was very specific after hours of research. I need someone with L2 manual. Thanks for your thought!
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:38 #889933
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1816
Any emmision banding for an exhaust will be for the complete system, if the bends and dimensions are the same the alternatives suggested should work (it's only a peice of pipe at the end of the day with nothing about it that will effect emissions)
CMNSL list 180491163 for the following
L3 - 1983
H - 1981
E1 - E2 - E3 1981-1983
I am sure there's more but I got bored, it appears that as Nessism said this is a pretty generic part. Given that the listed fitments are both older and newer than yours I think you are "over thinking it" but that's only my opinion
Last edit: by Wookie58.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 11:41 #889934
  • thanos12
I am completing restoring it and due to a flood I lost the manual! I am almost at 95% percent. I saw the forum and I just hit the question if anyone has it. Now if anyone has it please a take a photo or just reply with part number. Thank you.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 12:13 #889935
  • Wookie58
  • Wookie58's Avatar
  • Moderator
If you are going for 100 point "correct" restoration then I understand your desire to get a part with the correct stamping so disregard my last post if this is the case
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 13:24 #889937
  • Nessism
  • Nessism's Avatar
Good luck with your search.  I can find a few different pipes on eBay USA, but photos show E005.  Bummer.  To my knowledge, the pipes aren't marked with a PN, so there is that complication also.
Help needed with Pipe Exhaust for Z750 L2 30 Sep 2023 13:31 #889938
  • thanos12
I have made the same research. I will wait an owner to post his L2 manual!
