exaust seal ...
  • MALCOLMHOULE
  • MALCOLMHOULE's Avatar Topic Author
exaust seal ...
22 May 2023 16:38
#885082
I bought new crush rings to seal the gap from the engine to the pipes but it seems that is a pretty big job - is there a way to seal this with out having to pull off the entire manifold?  is it possible to do one pipe at a time?
  • TexasKZ
  • TexasKZ's Avatar
Re: exaust seal ...
22 May 2023 17:11 - 22 May 2023 17:12
#885083
Unless you have an aftermarket system with separate pipes, the whole header has to come loose, so you will need to replace all four gaskets. It is a little fiddly,  but one person can do it..
A little dab of grease on each gasket will hold them in place as you reattach the header.
Last edit: 22 May 2023 17:12 by TexasKZ.
The following user(s) said Thank You: MALCOLMHOULE
  • sf4t7
  • sf4t7's Avatar
Re: exaust seal ...
22 May 2023 20:21
#885088
And scotch tape (because it's thin) around the 2 inserts for each header tube to hold them as you assemble.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • MALCOLMHOULE
Re: exaust seal ...
23 May 2023 14:35
#885105
does this involve loosening removing the entire exaust system?
  • TexasKZ
  • TexasKZ's Avatar
Re: exaust seal ...
23 May 2023 18:21
#885114
I seriously doubt it, but that may depend on what exhaust system is on the bike. Typically, you just need to remove the eight nuts and the clamps. There should be enough room and flex to get the pipes out of the way far enough to remove and replace the old gaskets. Be sure to soak the nuts and studs in a good penetrating oil like Kroil or Liquid Wrench ( not WD40). The studs are small and easily buggered. Also pay close attention when removing the old gaskets, as there might be more than one at each port.
  • hardrockminer
  • hardrockminer's Avatar
Re: exaust seal ...
23 May 2023 19:22
#885116
I don't think you will be able to move the downpipes without unbolting the rear exhaust hanger(s).  Don't remove the long bolt...just remove the nut and that should allow enough room to pull the pipes forward enough to get at the gaskets.
  • TexasKZ
  • TexasKZ's Avatar
Re: exaust seal ...
24 May 2023 09:09 - 24 May 2023 09:10
#885127
If there is a clamped joint between the collector and mid-pipe, then loosening that joint should be enough. Again, it depends on what sort of exhaust system is on the bike.
Last edit: 24 May 2023 09:10 by TexasKZ.
The following user(s) said Thank You: hardrockminer
