Crankshaft difficult question.
- DFIGPZ
Re: Crankshaft difficult question.
11 May 2023 14:34If MLMG does not take the rods I’d be interested. I have a 81 J crankshaft with a bad rod. Are your 1024 numbers rods?MLMG
rods were not serviced seperate from Kawasaki, Crankshaft sold ass assy, now you can send to rebuilder to tear apart & check it then reassemble and weld, I expect this is from 1977- 1980 KZ1000 [ 1015 ] Engine ? I have a set of brand new take off connecting rods from a NOS "J" motor KZ1000 [ 903 ] engine these will fit the 1015 crank but you would have to mill .040in off block to maintain your current compression ratio, these rods were pulled from NOS new "J" crank so it could be fitted with 83/84 GPZ 1100 rods if interested I will let them go ?
yes they are 1024 marked "J" model rods I also have NOS " J" model crankshaft assy to part with
1984 750 Turbo
- DFIGPZ
11 May 2023 14:36
hence the reason I indicated he would have t deck block .040in
1984 750 Turbo
13 May 2023 17:57
DFIGPZ, I’m interested in the rods seeing how the OP can’t used them.
- DFIGPZ
21 May 2023 08:37
yes they are 1024 rods email me direct a b.flood@myactv.net put in subject line "J" Rods
Barry
Barry
1984 750 Turbo
