Chain/sprockets 01 Feb 2023 17:21 #879614
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Thank you received: 175
Z1, KZ900 and the early KZ1000's to 1980 (and 81 cop bike) use a 13-tooth spline front sprocket.  18T/42T 530 is the equivalent to the OEM 15T/35T 630 sprockets.
530 chain is 5/8 pitch, 630 is 3/4" pitch (6/8") - to convert 630 to 530 divide by 5 and multiply by 6.  The same is true with chain length.  92 link becomes 110 link.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
The following user(s) said Thank You: Scirocco, Wookie58
Chain/sprockets 02 Feb 2023 13:47 #879668
  • Irish Yobbo
  • Irish Yobbo's Avatar
  • Thank you received: 93
When I got my KZ750 LTD I think the previous owner/mechanic ordered a rear sprocket by looking it up, instead of checking what was on the bike. A KZ750 twin uses a 38T rear sprocket, which is what mine had along with the original 13T front sprocket. It was a rocket off the line, but I was in 5th most of the time because the gearing was so low.
I changed to a 530 chain/sprocket set. I went with a 16T front (part number JTF513 -16), and a 38T rear (part number JTR488 -38) using JT sprockets, and a DID chain (DID50VX114).
There is probably enough space to go one sprocket up on the front (to a JTF513 -17), I wouldn't try going any higher, there isn't much room there.
1981 KZ750 LTD
