Piston Hole Kz1000LTD 1982
- cartal
Re: Piston Hole Kz1000LTD 1982
19 May 2024 22:26
Yes! I got the starter one ok. Will get the engine grounded. Thank you!
20 May 2024 17:00
Both ground wires with the ring terminals connect o battery negativ.
The ground ring terminal have connect to the right engine case next to the upper rear engine mount.
The ground bullet connector to the main wiring loom.
The following user(s) said Thank You: cartal
- cartal
29 May 2024 11:45 - 29 May 2024 13:19
I know it’s not a lot, but we have cranking and spark in all 4 cylinders.
youtube.com/shorts/I2NDuYqBdFw?si=yo_LxUG3XKnc6asJ
carbs next!
carbs next!
Last edit: 29 May 2024 13:19 by cartal.
- sf4t7
29 May 2024 21:15
Another step checked off ! That's a good thing.
Scotty
1974 Z1A
Yoshimura 987 kit
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987 kit
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- cartal
30 May 2024 05:36
30 May 2024 10:21
Yeeehaw!
What was the problem with the forks?
- cartal
30 May 2024 22:29
I was missing one of the bottom little springs!
The following user(s) said Thank You: TexasKZ
- cartal
02 Jun 2024 13:08
Carbs update. What a disaster carbs were! Missing some springs, missing one main jet gasket, dry gaskets everywhere and above all, a dented diapragm "case" that does not go up and down. Terrible... and the most probable cause for the original piston hole.
Also, needle heights were wrong. All of them in position 4, rather than 2 (from the top, which indicates the manual).
In any case; I reassembled everything today, and still need to get 1 new diaphragm. Also, I need to find one of the "thick" rubber o´ring that sits under the main jet. I understand order is jet, washer, o´ring. It has "fiber" or plastic jets, not brass.
Any pointers on where can I find this o´ring I´m missing?
- cartal
02 Jun 2024 22:13
To get things a bit worse, I just realised one of the 4 mixture bolts is sheared inside its location.
the never ending adventure!
02 Jun 2024 23:21
03 Jun 2024 01:11 - 03 Jun 2024 01:19
....how to remove the broken tips
Last edit: 03 Jun 2024 01:19 by Scirocco.
The following user(s) said Thank You: cartal, Wookie58
- cartal
04 Jun 2024 07:15
Thank you Scirocco. This looks great.
I will try as soon as possible and see if this will work. My question, even before trying, is: How can the stuck bolt be extracted by pushing into that little hole, if the bolt is screwed into the carb body?
Not questioning it will work or not, just curious.
C.
C.
