  • Page:
  • 1
Piston noise 08 Dec 2022 19:07 #877644
  • Fox
  • Fox's Avatar Topic Author
  • Thank you received: 3
Hello,
after 30mm of ride when the engine is hot i can hear a fiction from the first piston.
The spark plug is wet and black. I have white smoke from the exhaust particulary at starting.
Just the rings to replace or overbore ?
What do you think ?
Thank you
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Piston noise 08 Dec 2022 19:38 #877645
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 292
Could it just be a fouled plug?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
Piston noise 08 Dec 2022 19:49 #877646
  • Fox
I ever try an other carb or other plug ... always that sound when the engine is hot
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Piston noise 09 Dec 2022 04:34 #877650
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1765
I would suggest you need to get in and have a look, before you can decide "rings or re-bore" you need to measure up. However if there is mechanical noise I would investigate sooner rather than later to avoid possible terminal damage (is there any metal in the oil?)
Last edit: by Wookie58.
Piston noise 09 Dec 2022 05:41 #877655
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1021
I think it's time to check compression.
  • Page:
  • 1
