  • Page:
  • 1
Cleaning corrosion and prevention 27 Nov 2022 11:00 #877232
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
  • Thank you received: 373
Taking apart the GPz engine and there is white corrosion on the bolts. I know I can wire wheel these clean but is there a way to clean off the corrosion without damaging the coating on the bolts? I assume the way to prevent future corrosion is liberal amounts of anti-seize?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: by ThatGPzGuy.
Cleaning corrosion and prevention 27 Nov 2022 11:36 #877235
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 369
You could try cleaning one with a brass brush (rather than a steel brush). Brass is softer than steel and is less likely to cause damage.
I like to use a brass wheel [in the cordless drill] with longer bristles to clean non-steel parts of the bike, like aluminum surfaces. Longer bristles will flex and will effectively be softer than short bristles.
Folks on this forum and elsewhere have mentioned that using anti-seize will probably cause you to overtighten the bolts. IIRC they were meant to be assembled dry, and the anti-seize acts like a lubricant when tightening so more force is required to achieve the torque spec in the FSM. But you'll want to explore that yourself - my memory isn't always great.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Cleaning corrosion and prevention 27 Nov 2022 11:39 #877236
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1756
Looking at the amount of rust on those bolts it looks like the coating has already failed, you could clean them off with a wire wheel and then you could "blue" them (a process used by gun makers to prevent corrosion
The following user(s) said Thank You: ThatGPzGuy, Nerdy
Cleaning corrosion and prevention 27 Nov 2022 12:07 #877240
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1892
I would try carb dip first as a non-abrasive solution.
Last edit: by Scirocco.
Cleaning corrosion and prevention 27 Nov 2022 14:06 #877248
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2670
The factory finish is zinc, with an olive drab dark chromate dip.  A brass wire brush may be useful, but the plating is already damaged, so there is only so much you can do.  Personally, if the heads still look okay, I'd wire brush the white corrosion off, then install using grease, or better yet, an anti-corrosion compound.  To fix the hardware properly, the old zinc would have to be removed, or at least the black chromate layer, then re-zinc plate everything yet again.
Cleaning corrosion and prevention 27 Nov 2022 14:23 #877249
  • ThatGPzGuy
Ok. I think I'll just clean off the corrosion as gently as I can. Nessism, what anti-corrosion compound would you recommend?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Cleaning corrosion and prevention 27 Nov 2022 14:50 #877252
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Could phosphoric acid be a option?
Project:
Cleaning corrosion and prevention 27 Nov 2022 15:45 #877258
  • ThatGPzGuy
It might be. I have some so maybe I'll try it on one of the bolts I'm going to replace. Good call.
I'm thinking I'll give the 'ol ultrasonic a try too.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Cleaning corrosion and prevention 27 Nov 2022 15:48 #877259
  • Nessism
  • Nessism's Avatar
Fluid Film makes an excellent corrosion protector.
Regarding phosphoric acid, it eats zinc.  I wouldn't use that stuff unless you want to strip the fasteners down to bare metal.
Cleaning corrosion and prevention 28 Nov 2022 11:57 #877272
  • linuxrob
  • linuxrob's Avatar
  • Thank you received: 43
Never use any acid to clean these bolts it may result in hydrogen embrittlement and cause the bolt to fail, just lightly clean the threads and install DRY.
1980 Z500 B2 owned from new 78260 miles
1980 Z500 B2 in bits since 1982 23000 miles
2004 GSF1200S Bandit K4
2000 GS125 ESD
Cleaning corrosion and prevention 28 Nov 2022 14:43 #877283
  • Nessism
  • Nessism's Avatar
I'm not an expert on this subject, but from what I've read, hydrogen embrittlement is mostly a concern with high strength fasteners,145ksi tensile strength and above, not the type used outside the engine on our KZ bikes.
For example, a Japanese bolt with a "7" on it is roughly the same as a SAE grade 5 fastener (the type with three hash marks on the head,) and those are rated to about 120ksi tensile strength.  "9" bolts, similar to SAE grade 8,  would be affected, but those are typically limited to things like cam caps, and they are not plated.
And BTW, I've got a Caswell's Plating zinc kit and use acid all the time.  Sometimes I'll strip the fasteners in HCl if they are really grungy.  If the fastener is in decent shape, I'll sometimes bead blast and wire wheel before plating, to save time.  And, actually, I think the plating process itself causes hydrogen embrittlement, far more than the cleaning and pickling process.  That's why high strength fasteners like rod bolts, APE engine studs, and similar are black oxide coated.  This doesn't damage the metal.  Black oxide is crap for rust protection though.  That's why GPz's use zinc with chromate black.
Cleaning corrosion and prevention 29 Nov 2022 04:28 #877298
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1020
I don't think hydrogen embrittlement would occur.  From what I remember from my university courses in welding technology hydrogen embrittlement occurs when a welder uses a damp rod while welding steel.  That's why they use warming ovens for welding rods.  Our prof had a famous story about a welder on a nuclear power project that stored his polish sausage in the welding warming oven to heat it for lunch, causing the rods to become damp.
  • Page:
  • 1
