Compression significantly different between throttle open and closed…why? 16 Jun 2022 20:04 #868943
  • jekyllman
  • jekyllman's Avatar Topic Author
  • Thank you received: 9
‘80 KZ650-F1. Pods.
I’ve been struggling with cylinder #2 not firing for months now. I’ve been completely unsuccessful diagnosing the issue. I feel like I’ve tried everything. However, today, while testing compression once again, I noticed that the three working cylinders will read around 135-145 psi cold and throttle closed. I panicked when I saw only 75 on cylinder #2 but that could explain it. However, I did it one more time with throttle open and….jumped quickly up to 145psi.
Can somebody explain to me why this would happen?! I’m pretty confused.
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
Last edit: by jekyllman.
Compression significantly different between throttle open and closed…why? 16 Jun 2022 20:19 #868944
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2670
Have you adjusted valve clearance?  And if so, did you find any valves with zero clearance?
Compression significantly different between throttle open and closed…why? 16 Jun 2022 20:43 #868945
  • jekyllman
I just finished up a valve seal job and verified all the clearances were in spec as well. So I think we're good there.
Compression significantly different between throttle open and closed…why? 16 Jun 2022 20:45 #868946
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
With the throttles closed, the piston going down makes negative pressure in the intake tract, thus not fully filling the cylinder giving the low reading. The compression test must be done with the throttle wide open to give an accurate reading.
Edit-Oops, did not see your reply about the valve job.
Last edit: by TexasKZ.
Compression significantly different between throttle open and closed…why? 16 Jun 2022 20:55 #868948
  • jekyllman
I know throttle open is ideal but usually we're talking 10-20psi difference. This was on the order of 70psi whereas the other 3 pistons were maybe 10 psi different when measured with throttle open.
Compression significantly different between throttle open and closed…why? 17 Jun 2022 00:56 #868952
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
A definitive "answer" can be attained by squirting a tablespoon or two of engine oil into that plug hole and measuring again...
An increase in pressure will indicate an issue with the bore and / or rings, being either worn and / or rings seized in the ring grooves.
My 2c
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Compression significantly different between throttle open and closed…why? 17 Jun 2022 01:20 #868953
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
  • Thank you received: 65
......or/and maybe the synchronization is not great, and the butterfly of #2 is almost closed...with not throttle, related to the others.
Last edit: by hugo.
Compression significantly different between throttle open and closed…why? 17 Jun 2022 04:22 #868960
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1021
Throttle closed means the slides are blocking air from flowing through the carbs and into the cylinders.
Compression significantly different between throttle open and closed…why? 17 Jun 2022 04:57 #868963
  • TexasKZ
  • TexasKZ's Avatar
You are right, I got nothin. I do know that the oil in the cylinder is a controversial method and that a leakdown test is more informative.
Compression significantly different between throttle open and closed…why? 17 Jun 2022 04:59 #868965
  • TexasKZ
  • TexasKZ's Avatar
As long as I am pissin in the wind, maybe there is a sticking valve in that cylinder.
Compression significantly different between throttle open and closed…why? 17 Jun 2022 05:03 #868967
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1764
The "wet test" method does work but you need to be sparing with the oil to avoid filling your tester with it
Compression significantly different between throttle open and closed…why? 17 Jun 2022 08:17 #868975
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
Shop air dialed down to 80 psi pumped it the cylinder is a poor mans leak down test. Make sure piston is at bottom dead center on power stroke. Listen at crankcase, exhaust, and carbs fo air leakage.
