Do a full throttle run
Then tape up half of your air filter intake to create a richer mixture.
Do another run. Did it pull harder?
Take off the tape then unscrew your air filter and leave a slight opening between your air filter housing and airbox housing.
Do not remove your air filter housing as that would be too much air.
You are creating a leaner mixture.
Do another full throttle run.
Which run was better? normal, lean, or rich?
Make sure your carbs are synced before testing.
Last edit: 17 Nov 2021 18:39 by F64.
