  • Page:
  • 1
Head hot enough to boil oil? 13 Oct 2021 09:41 #856590
  • rokit_armor
  • rokit_armor's Avatar Topic Author
  • Thank you received: 13
After a quick ride home yesterday from work (~2 miles) the top end on my bike was quite hot- I could hear boiling/popping sounds from inside. I've got my timing dialed in, and carbs jetted (a hair on the rich side) so I'm pretty sure it's not running hot due to a lean condition. Would the oil pressure from a stock pump be enough to cool a hot street build, or should I invest in an oil cooler? Is there a high-flow/pressure oil pump available as well?
Head hot enough to boil oil? 13 Oct 2021 16:43 #856607
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2671
Most of the late KZ bikes ran an oil cooler.  That doesn't mean they are necessary though.  I'm not sure about the shaft drive 1100 but with a lot of KZ engines you can install a later oil sump cover pan with the oil cooler takeoffs built in which makes installing a cooler easier.  That's what I did with my 750 anyway.  If you just ride your bike around in a sane fashion I'd skip the cooler.  As a mitigation against overheat abuse you can run synthetic oil which has a much higher vapor temperature compared to mineral oil.
Head hot enough to boil oil? 13 Oct 2021 18:37 #856613
  • rokit_armor
Well that's just out of the question
I just changed the oil with some Liqui-Moly 4T 15w50, I don't think its syntheic.
I'll see about the sump cover pan, finding a GPZ takeoff is turning into an expensive endeavor.
Head hot enough to boil oil? 14 Oct 2021 03:50 #856625
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
If your head is boiling oil? Something is too tight in that valve train!
Head hot enough to boil oil? 14 Oct 2021 06:00 #856627
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
I think I would get an infrared thermometer and find out for sure if something is getting too hot, and if so, what, before I began randomly replacing parts.
Head hot enough to boil oil? 14 Oct 2021 07:17 #856631
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 630
Do BS34 carbs provide adequate air/fuel flow for an 1170 engine with high lift cams?
RS36's+ would on my Christmas list.
1982 KZ1100-A2
Last edit: by daveo.
Head hot enough to boil oil? 14 Oct 2021 08:05 #856633
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
This is very good advice.  Harbor freight sells one for $25.
My dad's '74 Z1
'00 ZRX1100
Head hot enough to boil oil? 14 Oct 2021 20:14 #856658
  • rokit_armor
They do seem to! I would not mind some RS36s, that would be a few Christmases worth though.
Head hot enough to boil oil? 14 Oct 2021 20:14 #856659
  • rokit_armor
I'll swing by HF tomorrow and snag one.
  • Page:
  • 1
