  • Page:
  • 1
High temp grease? 13 Sep 2021 17:13 #855237
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
FSM recommends using on clutch pusher (inside basket)
When I took it apart is was looking like gray anti-seize.
What is this grease? Is regular bearing grease (M1 synthetic) going to work?
High temp grease? 14 Sep 2021 06:41 #855247
  • katit
Noone? I guess any grease will do? Mainly curious what kind of grease is that because it didn't wash out with oil..
High temp grease? 14 Sep 2021 07:10 #855248
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
The grease I remember using originally was called Black Pearl? basically a moly grease. We used the same grease mixed with motor oil as assembly lube.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: DOHC, katit
  • Page:
  • 1
