  • Page:
  • 1
What would happen if I removed one of the valve springs.... 04 Sep 2021 15:56 #854823
  • jekyllman
  • jekyllman's Avatar Topic Author
  • Thank you received: 9
I'm sure I'll get flamed for my ignorance but I'm in the middle of trying to swap valve stem seals on my KZ650. I'm a bit surprised by how stiff the valve springs are. It's making it tough to get the keepers off so I can do the swap. Theoretically, what would happen if I removed the inner spring and left the outer on each valve? Seems like there's plenty of tension to return the valve easily with just one....
1980 KZ650F1 - 10k miles (see photo)
1981 KZ305 CSR - 10k miles (didn't have the heart to customize this one, will stay original)
Last edit: by jekyllman.
What would happen if I removed one of the valve springs.... 04 Sep 2021 16:02 #854824
  • azman857
  • azman857's Avatar
  • Thank you received: 111
Your valves would be kissing the pistons wrecking everything.
What would happen if I removed one of the valve springs.... 04 Sep 2021 16:28 #854825
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Yeah bad idea.
Also I  recommend getting new stock springs because your bike if I remember correctly has very low miles and that means that some of those springs were compressed for 40 years and some of them weren't.
I think that your valves should be fine with just a clean up and a simple lap job.
Are you using one of these?    5 Sizes Valve Spring Compressor Pusher Automotive Tool Car Motorcycle | eBay
If not , they are a good investment, you don't want to bend a valve because it then isn't simple or cheap anymore.
78 KZ1000 A2A
What would happen if I removed one of the valve springs.... 04 Sep 2021 17:50 #854827
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 351
Valve spring pressure isn't gauged by your hand.
That's what this tool is used for.
www.intercompracing.com/arbor-valve-spri...re-tester-p-105.html
And why do you think they used 2 springs instead of 1 stronger spring??
Harmonics, dampening, and valve float.
Valve spring seat pressure is only one part of that spring design.
www.cycleworld.com/2013/12/24/valve-cont...-3-by-kevin-cameron/
81-KZ440-D2.
LIC, NY
Last edit: by F64.
What would happen if I removed one of the valve springs.... 04 Sep 2021 17:57 #854829
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2673
Draw a new redline at 5000 rpm and it's all good.
What would happen if I removed one of the valve springs.... 04 Sep 2021 18:13 #854831
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
  • Thank you received: 65
Am curious.  What are you using to compress the springs???........is the head out of engine??
What would happen if I removed one of the valve springs.... 05 Sep 2021 14:41 #854870
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
I'm pretty sure Kawasaki knew what they were doing when they built these engines, as said above, removing any valve spring will end up in tears...
PS, nothing wrong with your question, I'm glad you asked, get yourself a valve removal tool , or borrow one, Valve springs are very strong for a reason....
What would happen if I removed one of the valve springs.... 05 Sep 2021 15:04 #854871
  • Ojisan rider
  • Ojisan rider's Avatar
  • Thank you received: 63
I may be little late but here are my experience.
Like many of us, I also work on cars. Pretty much any car but my favorites are American Classic. I can't afford real classic cars, so I myself drive 86' Monte Carlo SS. Anyway, one of the first thing many of us that work on classic American V-8 is like our bikes, change out carb, swap out the cam, put in different piston (to raise the compression) and such. But even from stock, these engines have rather weak valve springs. Usually with single springs with dampers. Without changing anything, changing the valve springs will raise the redline because valves stop floating. Now, I'm not saying by simply changing the valve springs will SAFELY raise the redline, but rather, it will stop the valve float at high rpm.
To this day, I haven't met anybody that put in a weaker springs or make the spring weaker just for the ease of the maintenance. Just look at it from different point. Just how often do you open or remove the head? Also, get yourself whatever tools necessary to do the job right. Flying valve springs are not fun, and it's very very dangerous.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • Page:
  • 1
