  • Page:
  • 1
"New" engine startup - runaway revs 21 Aug 2021 12:43 #854153
  • idmurp
  • idmurp's Avatar Topic Author
  • Thank you received: 2
Hi all
first ever engine build, be nice ;)
Kz1000p. Rebored +0.5mm. Dyna ignition and coils. Fully rebuilt
Starts on first push of the button.  At very very high rpm. No taco connected yet so can't say how high, but very high.
I dont have anything on the cam cover breathers
We noticed the butterfly were very slightly open when removing carbs, but only by a little, not fully open
it was like we had throttle fully open, it was not.
where else should we be looking?
Edit
all rubbers are new
1992 KZ1000p in pieces
Last edit: by idmurp.
"New" engine startup - runaway revs 21 Aug 2021 13:17 #854154
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1895
Check and verify your throttle cable routing and slag is set correct. You need some play on the throttle handle.
The following user(s) said Thank You: idmurp
"New" engine startup - runaway revs 21 Aug 2021 13:32 #854156
  • idmurp
There was no play....
Carbs are off now, they look ok, It's late here now, we are opening beers and will play with the this again Monday night when we have had peoples opinions.
  • Page:
  • 1
