Does painting engine fins reduce cooling. 19 Aug 2021 17:43 #854079
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
I believe the original Gun Kote is what KG calls their series 1600 coating.
Gun Kote has to be sprayed on parts pre-heated to 100 degrees or so.
Then after spraying the parts have to be baked at 300 to 325 degrees for at least one hour.
I use my family oven to cure my Gun Koted parts.   The next 5 or 6 pizza's I cook in the oven do taste a bit funny after baking the Gun Koted parts!!!!!
1986 RG500G 2 stroke terror.
Last edit: by Dr. Gamma.
Does painting engine fins reduce cooling. 19 Aug 2021 18:40 #854082
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
That reminds me of an old joke
Two cannibals are eating a clown, one  cannibal turns to the other and says " does this taste funny to you?"
Sorry
78 KZ1000 A2A
Does painting engine fins reduce cooling. 19 Aug 2021 20:12 #854087
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
Seems like there was a build thread around here in which the builder used gold gun coat on his engine.
Does painting engine fins reduce cooling. 20 Aug 2021 01:58 #854092
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Here's a link to the data sheet for the 2400/2500 series, they refer to it as gun kote
shop.kgcoatings.com/kg/wp-content/upload...Data-Sheet-Rev-B.pdf
