  • Page:
  • 1
Valve Seal Spring Bent 15 Aug 2021 13:40 #853858
  • Jakob
  • Jakob's Avatar Topic Author
  • Thank you received: 0
Hello all,
I bent a couple valve seal springs that wrap around the top opening when putting new ones in.
Question: Is this the end of them? Should I replace or will they be okay.
Really don't want to have to reorder and redo but if I have to then it is what it is.
Thanks,
Jakob
Last edit: by Jakob.
Valve Seal Spring Bent 15 Aug 2021 14:16 #853860
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
They definitely will not function as "new" valve guide seals in that condition.  I personally would bite the bullet, reorder and chalk it up to a learning experience. They say experience is a very good, but sometimes expensive teacher!  At least you will then have peace of mind.
JMO,  Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: Jakob
Valve Seal Spring Bent 15 Aug 2021 15:19 #853869
  • Jakob
Thanks Mike,
I agree, these are relatively cheap compared to other parts that could get broken. Your input is greatly appreciated.  Gonna re-order, replace, get some peace of mind, then keep on learning. :):)
Thanks,
Jakob
Valve Seal Spring Bent 15 Aug 2021 15:57 #853873
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
One of our member sells Viton seal. I just can’t think of who. He advertises them in his signature.
EDIT, Found him…. www.kzrider.com/forum/profile/18962-dfigpz
Last edit: by Mikaw.
  • Page:
  • 1
