  • Page:
  • 1
  • 2
CLUTCH ISSUES 11 Aug 2021 14:48 #853602
  • aquaholic
  • aquaholic's Avatar Topic Author
  • 1981 KZ1000 J1
  • Thank you received: 36
Hey there fellow bikers, I am in need of some advice. 1982 KZ1000J. After rebuilding the engine and reinstalling, my clutch lever was extremely difficult to pull. It did work but I wanted to adjust the tension and play at the lever. I removed the adjustment screw cover and attempted to turn the screw per the manual. The manual stated to turn the screw in until it became hard to turn so I tried to back it out to adjust per the manual. It was very difficult to turn in either direction. I then pulled the cover to ensure nothing was hung up. While loosening the bolts the cover pushed away from the crankcase about 1/8" to 1/4". After I made sure that nothing was binding I placed the cover back on. The cover was still away from the crankcase and needed the bolts to pull it back in. The dowel pins were aligned properly. Is there anyway that the clutch push rod could be hung up somewhere. I would assume that the cover should go on without any resistance and without needing the cover bolts to pull it in. Any help will be greatly appreciated. I have owned several bikes and never had a clutch lever that pulled this hard. Thanks in advance, stay safe and be well. Jon
CLUTCH ISSUES 11 Aug 2021 16:43 #853609
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
I’d back off on the adjusted bolt before assembling the counter sprocket cover. Before you do, you should pull the push rod out and and check it for straightness. Install the cover and adjust per manual.
CLUTCH ISSUES 11 Aug 2021 20:16 #853621
  • richard-GPZ
  • richard-GPZ's Avatar
  • Thank you received: 9
You may have one of those clutch adjusters that have to be turned counterclockwise to tighten and clock wise to loosen.
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
The following user(s) said Thank You: aquaholic
CLUTCH ISSUES 11 Aug 2021 21:20 #853624
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Did you change any part of the clutch when you did the rebuild?  Is it the same push rod?  Did you change anything with the clutch pusher mechanism on the chain cover?
My dad's '74 Z1
'00 ZRX1100
CLUTCH ISSUES 12 Aug 2021 06:31 #853634
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
By richard-GPZ:  You may have one of those clutch adjusters that have to be turned counterclockwise to tighten and clock wise to loosen.
Yes, his should be the type.
From the 1981-83 FSM. 82 Supplement section. 10-18. Counterclockwise first until hard to turn. Then clockwise 1/4 turn.
The manual bolded the two words to hi-light the direction.  The owner's manual probably has the procedure.
Last edit: by martin_csr.
CLUTCH ISSUES 12 Aug 2021 17:28 #853672
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Martin is correct. Kawasaki started installing the EZ pull in the 1000s in 1982. The 1981 J engine had the older mechanism used in the Z, KZ and MKll engines.
CLUTCH ISSUES 12 Aug 2021 19:53 #853681
  • richard
  • richard's Avatar
  • Thank you received: 15
You said the lever can still be pulled
but it's very difficult
Any chance Barnett clutch springs were installed during the rebuild?
CLUTCH ISSUES 14 Aug 2021 13:05 #853807
  • aquaholic
  • 1981 KZ1000 J1
I did back the screw all the way out when I had the cover off. Per the manual after the cover is back on it says to screw the adjusting screw in until it gets hard to turn. Since I have to pull the cover in with the bolts the screw will not turn either direction. Haven't checked the rod yet but thats next. Thanks for the reply and advice.
CLUTCH ISSUES 14 Aug 2021 13:07 #853808
  • aquaholic
  • 1981 KZ1000 J1
The clutch plates are original. Thanks for the advice though
CLUTCH ISSUES 14 Aug 2021 13:11 #853809
  • aquaholic
  • 1981 KZ1000 J1
All parts are stock. I'm going to pull the rod and check for straightness. Then I'm going to pull the clutch housing cover and make sure all is well in there. Hotter than Hades out so I'm going to wait until it cools down a bit. Thanks to everyone for your thoughts and ideas. It is much appreciated.Jon
CLUTCH ISSUES 14 Aug 2021 13:25 #853811
  • Mikaw
  • Mikaw's Avatar
Is the clutch working at all? Not sure if it’s even possible but did you by mistake put the pusher ball in from the wrong side? It should be under the pusher on the clutch side? Just brainstorming possibilities.
CLUTCH ISSUES 14 Aug 2021 14:45 #853813
  • TexasKZ
  • TexasKZ's Avatar
Something internal is definitely amiss. The cover should seat fully with no resistance at all.
  • Page:
  • 1
  • 2
