  • Page:
  • 1
  • 2
crankshaft zx550 (GPZ550) 06 Aug 2021 13:02 #853267
  • Fairing_d87
  • Fairing_d87's Avatar Topic Author
  • Thank you received: 0
friends i have trouble!  bought an engine but it is defective.  broken two teeth on the crankshaft.  a question, tell me, the crankshaft from KZ 750 is suitable for the KZ550 engine (ZX550-GPZ550)
crankshaft zx550 (GPZ550) 06 Aug 2021 15:17 #853281
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1967
Welcome to KZRider
Sorry for your bad luck
 Im not a 650 guy / expert , but I think it will fit
 Im sure others with first hand knowledge will chime in
The following user(s) said Thank You: Fairing_d87
crankshaft zx550 (GPZ550) 06 Aug 2021 15:55 #853287
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1897
Nope.
GPZ 550 bore/stroke = 58 x 52,4 mm
GPZ 750 bore/stroke = 66 x 54 mm
KZ 650 bore/stroke = 52 x 54 mm
crankshaft zx550 (GPZ550) 06 Aug 2021 23:23 #853316
  • Fairing_d87
Thank you, the patient is just convinced. then another question will come from zephur (zr550) ???
crankshaft zx550 (GPZ550) 07 Aug 2021 06:40 #853331
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2053
I am just wondering out loud (in electronic print) if the 750 crank and rods could be used with 550 block, pistons and head, for a 58 X 54mm combo?
crankshaft zx550 (GPZ550) 07 Aug 2021 06:58 #853334
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2673
650's and 750 share a lot of engine parts, but not with the 550.  The smaller engine is quite different.
crankshaft zx550 (GPZ550) 07 Aug 2021 07:01 #853335
  • TexasKZ
  • TexasKZ's Avatar
Looks like the same part number for Zephyr and GPz.
www.partzilla.com/product/kawasaki/13031...ae66e4cfe67886ff8b95
crankshaft zx550 (GPZ550) 07 Aug 2021 10:50 #853350
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Cylinder spacing is closer on the 550 than 750/650. That should make for a challenging fitment project.
Last edit: by loudhvx.
crankshaft zx550 (GPZ550) 07 Aug 2021 18:49 #853387
  • TexasKZ
  • TexasKZ's Avatar
What’s a little rod curve between friends?
crankshaft zx550 (GPZ550) 08 Aug 2021 20:35 #853427
  • Fairing_d87
Thank you very much!  I will search from him, it is easier to find him.  after I write about the results (instagram  #wiats)
Last edit: by Fairing_d87.
crankshaft zx550 (GPZ550) 08 Aug 2021 21:42 #853428
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 351
or you could just have the gear repaired
81-KZ440-D2.
LIC, NY
crankshaft zx550 (GPZ550) 11 Aug 2021 03:57 #853557
  • Fairing_d87
I thought about it too.  but where can I find such a good uncle in the video))) I'm considering this option if I don't find a crankshaft
  • Page:
  • 1
  • 2
