Cam install help 23 Jul 2021 09:15 #852355
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
When you were trying to install the tensioner and it wouldn't fit....what was the problem?  I've never had a problem installing the tensioner by the method I described above.
If all of the slack is between the cams it is impossible for the intake cam to rotate.  But if there is slack on the tensioner side it will allow the intake cam to rotate forward as it's tightened down.
Cam install help 23 Jul 2021 10:50 #852364
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Perhaps I just got lucky twice with my KZ-1000, but I don't ever recall going thru all of this "effort" to install my cams.  I followed what the FSM said and everything just seemed to fall into place.  After installing the cams I tightened them into place by turning each cam cap screw a little at a time and it went smoothly.  After the cams were in and caps torqued down I went back and double/triple checked the pins and marks and installed the top idler.  I don't recall checking for chain slack front or rear.  2600 miles later it still runs and runs great.  Maybe ignorance is bliss.  I will admit that I never thought to use the starter or kicker to rotate the engine at any point in this process.  I just used a wrench on the end of the crank shaft so I could hopefully feel for any interference before it caused real damage.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Cam install help 23 Jul 2021 18:27 #852399
  • hardrockminer
I used to use a wrench on the timing bolt until one day I broke the pin located on the crank.  Had to tear the entire engine down, replace the pin and then rebuild from square 1.  That's why I use the kicker now.  If you're careful you can be just as accurate.  Just don't do it with the plugs installed.
Cam install help 24 Jul 2021 07:48 #852425
  • Rick H.
  • Rick H.'s Avatar
Interesting HRM, how and why did that pin break?  That seems like a pretty rare occurrence to me.  Not to split fine hairs, but I found I had a better "feel" for any hitches using a wrench versus the kicker, but that is just my opinion.  When I was doing my engine I had the bike on a lift and the kick lever was up much higher than it would be with the bike on the ground.  I didn't have any real feel for the kick lever so the wrench was a better option.
Rick H.
Rick H.
Cam install help 24 Jul 2021 18:47 #852470
  • hardrockminer
I can only speculate on the hows and whys.  Bottom line was a complete teardown, plus a 200 km drive to my favourite machinist to remove the stub and install a new pin.  Then put everything back together again.
Go with what works Rick.  The manual recommends a wrench on the crankshaft timing bolt. But the only thing holding it is the pin to set the timing device in the correct position.
I use a lift as well.
Cam install help 22 Aug 2022 14:58 #872654
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
  • Thank you received: 34
I am working on the valve clearances.  Was surprised at the small tolerances...  .05 to .10 mm??? that' like a couple piece of paper.  What's the best source for these 29 mm shims while I'm on the subject?
Clearances need to be 0.10 to 0.15mm.
.05 to .10mm are the old Z1 clearances which were superseded.
Aim for the wider 0.15mm .
is the superseded rule due to ethanol blended fuels making engines run warmer?
1982 KZ1100D1
Last edit: by Gdailey2112.
Cam install help 22 Aug 2022 16:47 #872661
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
No.  The change happened 40 years ago.
