Head Gasket Repair 01 Apr 2021 05:59 #845904
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
  • Thank you received: 35
I finally found someone to repair my 305's head gasket but he wants me to order all needed parts. What do I need, other than the head gasket??
Head Gasket Repair 01 Apr 2021 06:05 #845905
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1467
Buy yourself a top end gasket set.
It should include all you need including exhaust gaskets and the valve stem seals if needed which are worth replacing whilst the head is off.
Head Gasket Repair 01 Apr 2021 06:28 #845906
  • 82KZ305Belt
No eBay APP ID and/or Cert ID defined in Kunena configurationAt first I thought you meant "high quality" by top end but I realize you just mean top end of the engine. But it begs the question, are all gasket sets created equal? I see Vesrah, Athena and this no-name "aftermarket" brand
Head Gasket Repair 01 Apr 2021 07:29 #845909
  • zed1015
  • zed1015's Avatar
Go for the higher quality Vesrah / Athena ones and steer clear of anything no name.
Head Gasket Repair 01 Apr 2021 09:34 #845918
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I have used Vesrah, which I think are very good, but for a head gasket I would go with OEM.  The problem is that they are hellishly expensive.
Head Gasket Repair 01 Apr 2021 09:59 #845921
  • gordone
  • gordone's Avatar
  • Thank you received: 67
In the longe run you save money and time using OEM parts in general?
Project:
Last edit: by gordone.
Head Gasket Repair 01 Apr 2021 10:36 #845924
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
Athena is garbage.
Head Gasket Repair 01 Apr 2021 10:38 #845926
  • 82KZ305Belt
OEM is apparently not available, at least the major ones needed.
Head Gasket Repair 01 Apr 2021 10:40 #845927
  • 82KZ305Belt
Athena is garbage.
I hope that's a vote for the Vesrah, because that's about all that's left...
Head Gasket Repair 01 Apr 2021 13:10 #845936
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 74
Vesrah is about the best you can get short of OEM.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
Head Gasket Repair 01 Apr 2021 14:59 #845946
  • 82KZ305Belt
Vesrah gasket kit has been ordered. Now what about valve stem seals? Any to stay away from or look for, if I can't find OEM?
Also this will be done by a guy who is not a classic bike expert. Anything about these old bikes I should warn him about, or that I should be prepared for him to screw up?
Last edit: by 82KZ305Belt.
Head Gasket Repair 01 Apr 2021 15:45 #845953
  • Nessism
  • Nessism's Avatar
When pulling the head the cylinder should be removed so the base gasket can be replaced too.  And some people like to replace the rings at the same time.  Guess that last part depends on the overall condition and wear on the bike...and the cost of the rings.
The following user(s) said Thank You: 82KZ305Belt
