Shank, My guy Jim Mangus stopped doing cranks. He refers people to Stanley Gardner up in Maine. Index and weld with new thrust bearing, Stan says they all usually need the thrust bearing. He charges $1250. This consists of separating all the pieces to clean all oils on the pins, for welding.
My opinion, I would just use a milled main bearing cap with the tool steel plate along with some APE case studs.
Or a MarkII or GPZ crank with bigger pins.
But if you plan on that turbo in the future? About 25-30 pounds of boost will start twisting that crank.
Dragbikes launching a hot sticky slick at about 8-9 grand from a dead stop will twist that crank. A slider clutch helps a little.
