  • Page:
  • 1
  • 2
Repainted tank now won’t run 1979 kz1000 st 20 Sep 2020 01:32 #835390
  • Diocletian
  • Diocletian's Avatar Topic Author
  • Thank you received: 1
Thanks I’ll look into that.I have the tank off so I will find video and do it.
Voyager xii
Kz 1000 st
Repainted tank now won’t run 1979 kz1000 st 20 Sep 2020 01:52 #835391
  • Diocletian
I just watched a video.Holy cow Batman I think your on to something.My tank looks clean but after watching video it must be done.Im going to buy the carbonate and hook it up with clips to a deep cell battery.I let you know how it comes out.Thanks again that will save me from pull carbs all the time
Voyager xii
Kz 1000 st
Repainted tank now won’t run 1979 kz1000 st 21 Sep 2020 12:15 #835478
  • Highway Magician
  • Highway Magician's Avatar
  • Thank you received: 34
Diocletian wrote: I just watched a video.Holy cow Batman I think your on to something.My tank looks clean but after watching video it must be done.Im going to buy the carbonate and hook it up with clips to a deep cell battery.I let you know how it comes out.Thanks again that will save me from pull carbs all the time
Read the warning about using a stand-alone battery for electrolysis:
www.fordgarage.com/pages/electrolyticderusting.htm
Here's some pics of the GPZ tank. I use folded-over iron rebar wire for the anode and a manual battery charger.
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
The following user(s) said Thank You: ThatGPzGuy, Diocletian
Repainted tank now won’t run 1979 kz1000 st 26 Sep 2020 12:36 #835693
  • Gearhead63
  • Gearhead63's Avatar
I've resurrected lots of bikes that have sat for awhile. Old tanks will have lots off debris in them depending on how they were stored. Definitely use a filter and check it often until you get a chance to clean the tank. I usually use an acid solution and flush it well. There are lots of new more environmentally friendly options for removing rust now. Haven't tried electrolysis but it sounds like it should work for rust.
1981 KZ 1100A1
1996 ZX6 EV conversion
1975 Fiat X1/9 project
The following user(s) said Thank You: Diocletian
Repainted tank now won’t run 1979 kz1000 st 28 Sep 2020 12:36 #835789
  • Diocletian
After looking for a old school battery charger I couldn’t find one.I hooked my battery charger to my deep cell battery and hooked it up to the tank.It worked well what I didn’t know is about flash rush.I did some research and luckily found out about a tank sealer red kote.Im wait on the sealer so after it comes in I’ll flush tank and apply it.hopefully it works.
Voyager xii
Kz 1000 st
Repainted tank now won’t run 1979 kz1000 st 28 Sep 2020 12:41 #835790
  • Diocletian
When I used the battery I made sure it wasn’t heating up.
Voyager xii
Kz 1000 st
Repainted tank now won’t run 1979 kz1000 st 29 Sep 2020 04:56 #835832
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Don't use Redkote. I had an H1 tank done professionally with Redkote and after a few years it had dissolved and was gumming up the petcock and carbs. Getting the rest of it out was a PITA.
I only use two-part sealers now like those from Caswell.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Page:
  • 1
  • 2
