  • Page:
  • 1
Exhaust baffle removal. 08 Mar 2020 09:29 #820548
  • Davey b
  • Davey b's Avatar Topic Author
  • Thank you received: 0
Has anybody removed their baffles for repair? Am I right in thinking that I just drill out the 3 rivets shown here then remove the baffle, as you can see it needs a bit of welding !!
1981 kawasaki kz1000 m1 csr
Exhaust baffle removal. 08 Mar 2020 11:37 #820555
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2671
No guarantee that removing those rivets will allow full baffle removal. You gotta fix that hole though so it would be a good place to start so...
The following user(s) said Thank You: Davey b
Exhaust baffle removal. 11 Mar 2020 01:35 #820731
  • Davey b
Yeah definitely, so does the circular part with the 3 rivets come away on it's own then ?
Don't think I can do a good repair with it on the bike...
Exhaust baffle removal. 25 Mar 2020 19:32 #821772
  • Wafflez
  • Wafflez's Avatar
I just got done removing the baffles on my 550 yesterday, and it was a bittch!!
I drilled out the 3 screws and it was just a cover plate with a another plate behind it. I ended up drilling about a hundred little holes around the edge and pounding it out. Then I had to weld a slide hammer onto the center pipe and ripping the center of the baffle out. It wasn't fun. I can send a picture of what the core of the baffle looked like in a bit.
The following user(s) said Thank You: martin_csr, Davey b
Exhaust baffle removal. 13 Apr 2020 07:07 #823221
  • Davey b
I only want to take the end plate off to get it welded as its rotted away a bit and blowing slightly. I drilled out the 3 rivets, but without risking damaging the chrome, I just couldn't shift it. I don't have any welding equipment so cant weld anything to it. I gave up in the end. Will have to get it to a garage !!!
  • Page:
  • 1
