  • Page:
  • 1
  • 2
84 GPZ 750 A series 12 Jan 2020 23:42 #817010
  • The_Fixer
  • The_Fixer's Avatar Topic Author
  • Thank you received: 0
Hi guys.
Was given a what I think is an A3 model a couple of years back, had been sitting under a tarp against a building for 5-6 years.
Have rebuilt the forks and unistrut setup, blasted and painted the frame.
Decided to pop the head off and have a look inside. The oil I drained was quite clean and the motor is very clean inside. Cleaned out the starter and found some new brushes and bearings. Brushes were kind of awkward to get, they only seem to sell the 4 brush setup and mine is a 2 brush one. Had to really shop around, using the vernier measurements and specs - got them from a Suzuki parts list.
Anyway, I measured the piston to wall gap, pecs says 0.06 mm, mine are 0.6mm. Looks like a rebore needed.
Parts guys seem to only want to sell the 810 bore kit, but I and a bit cautious of that, in case it leaves me with nowhere to go in case of a future next rebuild.
A mate of mine has an 80 Z1000 MK II. He's had it tricked up a bit and was advised by his mechanic not to go for the full blown oversized kit. Reckons the bike don't seem to get their best from it and going up just a little bit makes the engine even better and you'll still have a rebuild left in it.
Anyone have any knowledge to share over a rebuild? I'm more interested in a good machine over max speed/power think (getting a bit past that stage now).
I had new bushes and grommets machined up to replace the crapped out ones in the unistrut suspension. Only cost me about $220 to completely rebuild that including bearings and seals.
84 GPZ 750 A series 13 Jan 2020 04:41 #817016
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2676
No eBay APP ID and/or Cert ID defined in Kunena configurationOEM oversized pistons are discontinued. You may be able to find a set from ebay but the path of least resistance is an 810 kit. Cruzinimage has a kit for a crazy low price that's actually pretty decent. I wouldn't worry about the over bore since old used cylinders are plentiful on ebay. And speaking of that, if you get lucky you may even be able to find a good used cylinder. You never know.
The following user(s) said Thank You: The_Fixer
Last edit: by Nessism.
84 GPZ 750 A series 13 Jan 2020 21:40 #817064
  • The_Fixer
Damn! Does not ship to Australia! That's a blow...
Thanks Nessism.
The big spend on the project is officially on hold for a spell whilst I take care of other things.
Otherwise the elbow grease side will progress slowly.
In the meantime, I'm just researching things and getting options together so a decision can be made later.
Do I need to re jet the carbies? still in the process of restoring them as well.
Last edit: by The_Fixer.
84 GPZ 750 A series 14 Jan 2020 16:51 #817083
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
I wish us 900 guys could go to a similar CC increase for that cheap
84 GPZ 750 A series 14 Jan 2020 22:59 #817098
  • The_Fixer
So far, I've found a few kits available here (even from the states) for around $1100. Mostly Wiseco stuff.
Pretty steep. I'll keep looking around and see what turns up...
84 GPZ 750 A series 16 Jan 2020 09:22 #817208
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Nessism wrote: OEM oversized pistons are discontinued. You may be able to find a set from ebay but the path of least resistance is an 810 kit. Cruzinimage has a kit for a crazy low price that's actually pretty decent. I wouldn't worry about the over bore since old used cylinders are plentiful on ebay. And speaking of that, if you get lucky you may even be able to find a good used cylinder. You never know.
How munch longer will a Wiseco piston set keep going? Or can it be the same? Only increase in compression only differens?
Project:
84 GPZ 750 A series 16 Jan 2020 10:43 #817209
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
>>> "Anyway, I measured the piston to wall gap, pecs says 0.06 mm, mine are 0.6mm. Looks like a rebore needed.
Parts guys seem to only want to sell the 810 bore kit, but I and a bit cautious of that, in case it leaves me with nowhere to go in case of a future next rebuild."
Kawasaki supplied two over size pistons for most models, usually 1mm (.039"), check with Kawasaki dealer.
84 GPZ 750 A series 16 Jan 2020 10:48 #817210
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1467
gordone wrote:
How much longer will a Wiseco piston set keep going? Or can it be the same? Only increase in compression only differens?
There is no comparison between the Wiseco and Cruzin image pistons.
You get what you pay for.
Wiseco are high performance forged pistons and the Cruzin image which are made in Taiwan are cast copies of the stock originals.
The following user(s) said Thank You: slayer61, gordone, The_Fixer
Last edit: by zed1015.
84 GPZ 750 A series 16 Jan 2020 16:40 #817222
  • Nessism
  • Nessism's Avatar
  • Away
If you google Cruzinimage pistons there is quite a bit of positive information. I don't think they measure up to Wisco but if you are not racing and money is a factor they will likely serve just fine for a good long while.
84 GPZ 750 A series 16 Jan 2020 16:41 #817223
  • Nessism
  • Nessism's Avatar
  • Away
73z1 wrote: >>> "Anyway, I measured the piston to wall gap, pecs says 0.06 mm, mine are 0.6mm. Looks like a rebore needed.
OS pistons are long out of production. I think they would be a great option if available, but that's a huge if.
The following user(s) said Thank You: gordone, The_Fixer
84 GPZ 750 A series 17 Jan 2020 02:56 #817243
  • gordone
  • gordone's Avatar
The winesco 810 I installed had higher compression then orginal.
Is it a cheap way of increase performance or is it cheaper ways to increase the same in performance?
Just ask so we compare on the same «basement».
Project:
84 GPZ 750 A series 17 Jan 2020 11:01 #817273
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Higher compression alone wont make a big difference in performance, however higher compression will let you run hotter cams effectively, and with port work/carbs it will make a big difference. Any one of those changes will not make a big difference alone but together they will.
  • Page:
  • 1
  • 2
