Can somebody help ?.... 05 Jul 2006 13:46 #59533
  • scorpio
  • scorpio's Avatar Topic Author
  • Thank you received: 0
I did all possible but I'm unable to find oil seals for the valves of KZ750 :( I think thay are not expensive, but impossible to find here (in Bulgaria) :( Still can't find piston rings also...but i hope it will be a little easyer to find...
Please, somebody send me a set of these oil seals if you can...i'm gonna pay you somehow...I will be very happy even if somebody send used ones in good working condition. Maybe little used rings will do their job also...at least better than nothing. I know here a people that like to help others and hope thay can help me too. So small things prevents me from rebuilding the engine :(
Post edited by: scorpio, at: 2006/07/05 16:53
Can somebody help ?.... 05 Jul 2006 14:06 #59534
  • kawsakiman
  • kawsakiman's Avatar
  • Thank you received: 6
check z1enterprises.com
Can somebody help ?.... 05 Jul 2006 14:21 #59540
  • kawadruida
  • kawadruida's Avatar
  • Thank you received: 1
Check these guys, they´re located in Germany
www.z-klasmo.de
Good luck!
Can somebody help ?.... 06 Jul 2006 05:50 #59620
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
Try putting your bike year/model in your signature. Is this a 4 cyl or 2 cyl KZ750?
Can somebody help ?.... 06 Jul 2006 06:57 #59631
  • trippivot
  • trippivot's Avatar
  • Thank you received: 3
what is your address? what is the exact model? no problem scorpio
Can somebody help ?.... 06 Jul 2006 07:00 #59632
  • oldcoldankles
  • oldcoldankles's Avatar
After doing a bunch of research I recall Mcdroid figured scorpio was working on a 1982 GPz750R1.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
Can somebody help ?.... 06 Jul 2006 07:45 #59638
  • wiredgeorge
I would guess that most any oil seals will work. Can't double check as the Kawasaki web site is having problems:
Can somebody help ?.... 06 Jul 2006 07:54 #59641
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 306
The frame was a 1982 KZ750R1 (GPz) the motor was a 1983-1988 KZ750 but still undetermined.:blink: The problem being our info on KZ750 motors (GPz) ends in 1985...they were still manufactured through 1988 for the European market...if there were any changes in seals (unlikely) we can't access that info.
Post edited by: Mcdroid, at: 2006/07/06 10:57
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Can somebody help ?.... 06 Jul 2006 09:51 #59660
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
  • Thank you received: 50
Damn, I thought I lived in the middle of nowhere!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Can somebody help ?.... 06 Jul 2006 11:20 #59678
  • wiredgeorge
The ends of almost all valve guides are about the same w/7mm holes for the valves. I used Z1/KZ valve stem oil seals on my Vulcan 1500 as the OEM valve seals were about $8 or $9 each... I can get a whole set of KZ valve stem oil seals for about that or just a few bucks more.
Can somebody help ?.... 06 Jul 2006 14:15 #59708
  • scorpio
Hello People,
You saw why i didn't put the model of the bike in the signature...still thinking what exactly to write there. But Mcdroid explaind it good. It is a four cylinder.
My mailing address is as follows:
Karjali 6600
jk. Vazrojdenci, Bl. 42, Ap. 52
BULGARIA
for Mr. Svilen Angelov
In case somebody will be generous enough to send me the parts. I will highly appreciate this, and than you in advance.
Can somebody help ?.... 07 Jul 2006 07:37 #59896
  • wiredgeorge
If someone would be so kind as to look up valve stem oil seals for an 83-85 750 and get the part numbers and cross them with oil seals for other models, I suspect it wouldn't be hard to mail a few... My cross ref software is kaput... it won't run on my computer and Steve Zedder gave me a bunch of help... something to do with Active X screwing up the working...
