  • Page:
  • 1
  • 2
Sounds of my 79 Kz750 Twin 11 Jun 2006 18:17 #53767
  • cnyl
  • cnyl's Avatar Topic Author
  • Thank you received: 5
We've been messin with tuning my carbs found that my boots were cracked allowing a vac leak. We went up on the main jets. I'm popping when reving it off idle
This is where i'm at. Take a listen tell me what you think.
Reving
media.putfile.com/Kz750-Rev
Idle
media.putfile.com/Kz750-Idle
Post edited by: cnyl, at: 2006/06/11 21:18
Post edited by: cnyl, at: 2006/06/11 21:19
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
Sounds of my 79 Kz750 Twin 11 Jun 2006 18:19 #53769
  • OKC_Kent
  • OKC_Kent's Avatar
  • Thank you received: 20
The links need work, I can't get anything. :(
Works now!! ;)
Post edited by: OKC_Kent, at: 2006/06/11 21:20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Sounds of my 79 Kz750 Twin 11 Jun 2006 19:34 #53781
  • steell
  • steell's Avatar
  • Thank you received: 207
The bike is only running on one cylinder at both idle and revving :)
I know the sound well, I actually rode my 80 750 twin on one cylinder when I first got it running, just wanted to see if it would do it :)
Which side exhaust pipe is not getting hot?
Post edited by: steell, at: 2006/06/11 22:34
Sounds of my 79 Kz750 Twin 11 Jun 2006 20:37 #53800
  • pumps
  • pumps's Avatar
  • Thank you received: 3
I think it is so cool I'm listening to your bike off the web! Ok so Im a geek!
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
Sounds of my 79 Kz750 Twin 12 Jun 2006 07:47 #53900
  • cnyl
Which side exhaust pipe is not getting hot?<br><br>Post edited by: steell, at: 2006/06/11 22:34
Hmmmmm. When I adjust both pilot screws they both make a difference. Let me check again.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Sounds of my 79 Kz750 Twin 12 Jun 2006 08:03 #53903
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
  • Thank you received: 7
cnyl wrote:
Hmmmmm. When I adjust both pilot screws they both make a difference. Let me check again.[/quote]
Is it possible that the recording mic was right next to one of the exhausts (if it's two-into-two), so it only picked up the one?
..I don't know, I can't listen to it on Linux, it's apparently a Windows-formatted file... :(
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
Sounds of my 79 Kz750 Twin 12 Jun 2006 08:12 #53906
  • cnyl
It's got a 2 into 1 on it. I just checked the headers and they are both hot but the right side is hotter. The mic was about 2 feet away from the pipe.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Sounds of my 79 Kz750 Twin 12 Jun 2006 08:14 #53907
  • Biquetoast
What RPM do you idle at?
kz750twins.com
Sounds of my 79 Kz750 Twin 12 Jun 2006 08:15 #53909
  • got12narow
  • got12narow's Avatar
  • Thank you received: 0
Don't claim to know much (just learning,) but my 77 seems to give the same popping. Only upon initial/cold starting. I've dug through the archives a bit, and found that if your boot from the air box to the carbs is leaking, then your running too rich? I think. I checked mine, and it is in fact torn. I haven't yet replaced them, but mine evens out and stops backfiring once it warms up.:)
Sounds of my 79 Kz750 Twin 12 Jun 2006 08:28 #53914
  • cnyl
According to the tach i'm running at 1000 or a hair over. For some reason the idle screw won't lower the rpm
anymore than it is.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Sounds of my 79 Kz750 Twin 12 Jun 2006 09:03 #53921
  • steell
  • steell's Avatar
Remove the spark plugs and post what they look like (#1 and #2).
A history of the bike and what you have done so far would help a lot :)
Sounds of my 79 Kz750 Twin 12 Jun 2006 12:35 #53976
  • cnyl
Hey steell,I pulled the plugs, the #2 looked normal but #1 was carbon fouled. So I cleaned it and put in the #2 cyl.(swapped).
It's running on both.:woohoo:
That seemed to be my problem. Runs great now I almost am afraid to do a sync.. Might mess it up.:laugh: I'll post another sound clip.
Oh..... The spouts that stick out of the intake boots, Do they need to be joined with a hose or plugged off separately?
Thanks all.:woohoo:
Post edited by: cnyl, at: 2006/06/12 15:39
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • Page:
  • 1
  • 2
