  • Page:
  • 1
shimming a head 29 Oct 2005 19:57 #5242
  • nads.com
  • nads.com's Avatar Topic Author
  • Thank you received: 20
I never mess with changing shims. I leave the valves out, put the buckets in with any old shim ive got, put the cam in, torgue it, slide in a valve and hope for no clearance. Then i grind the stem untill ive got the spec i want. Fast, simple. Ive never had a problem and it its very accurate. I can hear the grinder right now. Love that grinder. makes cam chain tensioners too.
shimming a head 29 Oct 2005 20:00 #5244
  • Bud1
  • Bud1's Avatar
  • Thank you received: 0
uh, what? :blink:
shimming a head 29 Oct 2005 20:11 #5249
  • steell
  • steell's Avatar
  • Thank you received: 207
nads.com has a unique writing style, seems to know what he's talking about though :D
What he is saying, is that he adjusts valve clearance by grinding the tip of the valve instead of swapping shims.
Of course that's a hard way to do it, unless you already have the cylinder head off the motor and the valves out :D
shimming a head 29 Oct 2005 20:52 #5263
  • Rickman
  • Rickman's Avatar
  • Thank you received: 1
Hmm, What does el grinderino make cam tensioners out of? Old cam tensioners?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
shimming a head 29 Oct 2005 21:00 #5267
  • Bud1
  • Bud1's Avatar
How interesting...
shimming a head 29 Oct 2005 21:31 #5272
  • nads.com
I hereby predict the ball will fall off of your shim tool............
shimming a head 30 Oct 2005 02:55 #5299
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
  • Thank you received: 59
And what do you do when you have too much clearance? Put two shims in? :laugh:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
shimming a head 30 Oct 2005 05:11 #5314
  • steell
  • steell's Avatar
Use the valve stretcher of course :D
shimming a head 30 Oct 2005 08:23 #5345
  • The Milkman
  • The Milkman's Avatar
  • Thank you received: 194
You guys have it all wrong. You grind the seat deeper.:P :P
shimming a head 30 Oct 2005 11:49 #5378
  • hwms
  • hwms's Avatar
Is Nads a holdover from the old 1937 Ford V8-60 days?
  • Page:
  • 1
