i don't think wiseco stocks the 8:1 1075 pistons anymore. that's what i was told, anyways, probably wrong.
if you want to run lots of boost, then mosdef wanna go as low as you can with the c/r. if you don't, then keep it under 8psi, run REALLY GOOD FUEL, and you also might want to consider running a good ignition that has timing retard curves that are boost referenced.
my 1075 turbo engine was built with 9:1 pistons, stock cams, rear-sump oil pickup(not a deep sump). yes, the old turbos MUST have a good consistant supply of oil. also, make sure that the lines are restricted properly, or your pressure will be too low. bearings are VERY sensitive to low pressure.
OH, huge one here, don't even dink around with the stock carb that comes with one of those kits, just get back on ebay, and buy a mikuni hsr 42. you will need the pressurized needle and seat setup. i can get the part number for this when i get home next weekend, or one of the other turbo guys can chime in.
get a good fuel delivery system as well. we can get into that later on.
www.dragbike.com has an AWESOME turbo forum as well. some very fast turbo guys over there. some of the kwak guys over here, too. 8^)
--r
