  • Page:
  • 1
  • 2
HI all 09 Oct 2005 18:42 #114
  • Brad78Kz650
  • Brad78Kz650's Avatar Topic Author
  • Thank you received: 0
Hello all I Stumbled onto this site looking for parts
and was wondering if i could ask for help. My dad gave me a 78 kz 650 and i have been trying to get in running and have been succesfull seems like all that was wrong with if is the kill switch went bad but anyway when it cranks it runs good but getting it to crank is really hard i was wondering if anyone has any ideas on what i could do to fix this im no mechanic but the bike was givin to me and i think if its not to bad i could fix it
so if anyone has any ideas the would be greatly appreciated thanks
Brad:evil:
HI all 09 Oct 2005 18:47 #116
  • DanOz7Five0
  • DanOz7Five0's Avatar
What do you mean getting it to crank? Is the starter turning slowly?
HI all 09 Oct 2005 18:57 #124
  • steell
  • steell's Avatar
  • Thank you received: 207
We need a little more detail in your post in order to be of any help :)
HI all 10 Oct 2005 06:47 #315
  • Brad78Kz650
no starter works fine it turns over (electric) and kicks over but it wont fire off seems like its only getting spark every so many cranks when it warms up it will crank fine till it cools down does that help any?
HI all 10 Oct 2005 06:48 #316
  • Brad78Kz650
Post edited by: Brad78Kz650, at: 2005/10/10 10:03
HI all 10 Oct 2005 08:04 #342
  • rivieracadman
  • rivieracadman's Avatar
Just a thought, but I had the same problem when I got my 650. I had low compression in the 3rd cyclinder. Weak spark on the first coil, and the jetting wasn't right. If the bike is running well once you get it started, I would check the coils first, then have a compression check done. Compression should be over 65lbs.
HI all 10 Oct 2005 09:50 #369
  • Brad78Kz650
Thanks muchly for the reply i know how to check compression but not how to check coils can i get a basic explanation? Never worked on a motorcycle before and no money for a shop :)
HI all 10 Oct 2005 16:47 #486
  • Brad78Kz650
I got messing with the bike today and found that the reason it would only start every so often is that the kill switch wires had a short in them. Now i got that it cranks good but if i try to turn the choke off it dies i give it time to warm up the only way i can get it to work right is with the throttle adjustment near the carbs any way of fixing this. I dont mind but i cant crank up and go i have to fiddle with it to get it right first so any help would be appreciated
HI all 10 Oct 2005 16:56 #496
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Welcome Brad to KZR. I find I need to let my bike warm up for a few minutes and even longer on cold days using the choke. I start her with the choke all the way up, then start lowering the chock lever to control the revs, not letting her rev too high.
You may need to give your carbs a good cleaning at some point as well as give your engine a tune up if they haven't been done recently.
Post up a picture of your ride in the photo section as well.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
HI all 11 Oct 2005 05:28 #625
  • BSKZ650
  • BSKZ650's Avatar
  • Thank you received: 14
that sounds like a normal thing to me, mine takes a bit for it to warm up and run right, just play with the choke and dont let it rev up too high,
my factory book says compression should be 135-205 lbs,with a 10% rnage between cyl.
77 ltd1000, current rider
76 kz900, just waiting
HI all 11 Oct 2005 05:39 #626
  • BSKZ650
  • BSKZ650's Avatar
HI all 11 Oct 2005 07:29 #649
  • Brad78Kz650
Well cant get it to start up again today:( but i guess ill keep messing with it but like i said im no mechanic if anyones has any other ideas let me know ill get some picks posted here in a sec
  • Page:
  • 1
  • 2
