- Thank you received: 1390
Differences between an LTD and a KZ900?
- KZQ
- Administrator
17 Jul 2024 20:47 #902290
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Differences between an LTD and a KZ900? was created by KZQ
I've got an old KZ900 frame that bears a manufactured date of 1/76. I bought it many years ago for the parts. I also have a KZ900 manufactured in 6/76. It is the standard bike with a drum brake at the rear. I'm working on another bike that needs some sort of generic rear master cylinder.
This old parts bike has been modified. I can see that the mounts for the rear master cylinder were welded on as part of an effort to add a disk brake to the rear of this bike. This master cylinder is of a vertical design. I'm thinking that it's the standard master cylinder from a LTD model.
Does anybody know a part or model number for this master cylinder.?
TIA
Bill
TIA
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Thank you received: 2280
18 Jul 2024 00:54 #902291
by Wookie58
Replied by Wookie58 on topic Differences between an LTD and a KZ900?
- Moose1800
- Thank you received: 296
18 Jul 2024 05:08 - 18 Jul 2024 06:20 #902296
by Moose1800
Replied by Moose1800 on topic Differences between an LTD and a KZ900?
It is indeed a one year only Wookie and if you need a rebuild kit it uses the same parts as the later KZ1000 LTD rear master but the master is shaped different, the front master is also a one year only and the front master on my 76 LTD has a 11/16" piston which a rebuild kit is a hard to find item.
Last edit: 18 Jul 2024 06:20 by Moose1800.
The following user(s) said Thank You: KZQ, Wookie58
- asphalt900
- Thank you received: 271
18 Jul 2024 05:18 #902299
by asphalt900
Replied by asphalt900 on topic Differences between an LTD and a KZ900?
In addition. The metal rod is specific to the LTD, it's longer. Also used a thinner head shouldered pivot bolt for attachment to brake pedal. Reservoir cap is the same as the front master cylinder, front is a 5/8" master for the duel disc brakes. Front calipers the same as the KZ900 and early KZ1000 but since mounted behind the fork lowers used different hard line brake piping tubes.
- Moose1800
18 Jul 2024 06:33 - 18 Jul 2024 06:54 #902301
by Moose1800
The front master cylinder on my 76 LTD has a 11/16" piston dia. it's stamped on the bottom, I had to use a rebuild kit from a 76 Goldwing. I must have an ultra rare master when I ordered a rebuild kit for it Brakecrafters sent a 5/8" kit, it was a no go, I worked with the folks at Brakecrafters to come up with the Goldwing Master rebuild kit. The front master on the later 77 and up LTD is indeed a 5/8" piston dia.
The piston on the left is 5/8" the one on the right is 11/16"
![[img](https://i.postimg.cc/xdfTYmtd/002.jpg)
![[img](https://i.postimg.cc/wBwmym8P/012.jpg)
Last edit: 18 Jul 2024 06:54 by Moose1800.
- asphalt900
18 Jul 2024 10:38 #902307
by asphalt900
Hey Moose! Seemed like quite a quest to find bits for that master. Hate to say it though, it's not an LTD900 76-77. They never had that extra molding for use of a brake switch and if the background represents the reservoir stuff, they didn't start using the plastic trapezoid cup till 1978. The LTD used a 5/8" taller solid smooth reservoir. Yes still unique though. Unlike the accessory 5/8" master used on the Z1 here in the states, some Euro countries it was standard equipment. Heres the piston kit, genuine K. And a couple original examples.
- Moose1800
18 Jul 2024 13:50 - 18 Jul 2024 13:59 #902316
by Moose1800
Hey Clay, I know you know your shit when it comes to these old bikes much more than I do but on the other hand I've owned this bike for almost 48 years and nobody knows it better than me, I bought it when I was 19 I'm almost 67 years young right now. This is the master that came with my bike as new, did mama Kaw stick it too me ? is it a prototype ? who knows, you and I both know the 76 b1 is a true limited edition bike with a bunch of one off parts. Another thing I noticed on the front brake calipers the piston is a bit larger on one side than the other, why did they that ? who knows I forget which side is which but it's another thing I noticed and have seen it mentioned here by Larry C the guy that did the head work here years ago or maybe it was Patton.
Pay no mind to the trapezoid parts, Brakecrafters told me to keep the 5/8" rebuild kit and sent me the 11/16" kit from a goldwing for free, I had trapezoid in need of a rebuild so I did both at the same time.
![[img](https://i.postimg.cc/sD9GrXS3/001.jpg)
Last edit: 18 Jul 2024 13:59 by Moose1800.
