ZR7 FSM
ZR7 FSM
06 Nov 2023 05:08
I have noticed that it is quite popular to use parts from the ZR7 in the earlier bikes, with this in mind I have added a ZR7 FSM to the "Filebase" (had to upload in 2 parts as the file is too big for a single upload !!)
The following user(s) said Thank You: Nessism, riturbo, Mikaw, rangeroy, Warren3200gt, howardhb
- Warren3200gt
Re: ZR7 FSM
06 Nov 2023 05:49
Common upgrade to fix the z650 starter clutch "issue" to a more robust 7rx one.
- rangeroy
Re: ZR7 FSM
06 Nov 2023 08:47
oil pump & pressure relief valve & clutch basket all fit earlier models, oil pump 20% more output & basket a lot younger so the rubber puck dampers are not as worn/hard.
1977 z650
