  • Page:
  • 1
  • 2
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 08:23 #876696
  • ShaneDude
  • ShaneDude's Avatar Topic Author
  • User is blocked
  • Thank you received: 13
1977 KZ650
Has Dyna Coils and Dyna S ignition
Bike ran great for 3 years.
I parked it in July after a long ride and let it sit for three months.
In October I started the bike and it ran funny. Looked at the plugs: #1 was wet with oil. At some point I will have to change the valve seals.
I pulled all the plugs to inspect them, and replaced the oil covered plug in cylinder #1. I didnt put the spark plug WIRES back in the correct firing order!!
For 3 weeks I struggled with why pipes 1 and 2 would not get hot. I pulled the carbs. Mostly they were clean. I was pretty impressed with how clean they were.
Put the carbs back on and got the same problem: backfiring and cylinders 1 and 2 not firing.
Called Dynatek.
The tech said the bike  is put of phase and to fix the problem I should reverse the spark plug wire order.
So I changed the spark plug wire order from the Left Hand Coil going to #1 and #4 to #2 and #3 and vice versa on the Right Hand Coil. Now the BIKE RUNS LIKE A CHAMP!
Below  is a pic of it today. Thanks to all the members of the forum who were civil, non-argumentative, and who sought to help. You know who you are.
I am very very happy the bike is running. Its a great feeling:
Last edit: by ShaneDude.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 08:58 #876697
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2620
How about a pic of you with the bike?
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 09:01 #876698
  • ShaneDude
  • User is blocked
Thanks for responding.
As you are a moderator, I dont have to tell you, this forum is about Kawasakis, not ppl. I prefer you see the bike.
I hope its good weather where you are. I will be out riding on the bike today.
Have a great weekend.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 09:28 #876702
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
  • Thank you received: 35
Damn. That's purty.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 09:30 #876703
  • ShaneDude
  • User is blocked
Damn. That's purty.
Thanks! I have other bikes but I love this green machine!
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 11:12 #876712
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
I know whose bike that is. It was so familiar to me.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 11:54 #876716
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
Get the popcorn.
Z1000J2 somewhat modified!
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 12:14 #876718
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1854
Ya just need to give some people enough rope!
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 12 Nov 2022 14:20 #876722
  • ShaneDude
  • User is blocked
This is a forum about motorcycles.
Perhaps your posts belongs in a  "general discussion" area where posts like this are more appropriate, and not in "engine!"
I am thankful the bike is running well and thankful to the people in this forum who chimed in to help.
It is my hope that anyone who may encounter the same issue, will find this post helpful.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 13 Nov 2022 07:00 #876740
  • SWest
  • SWest's Avatar
  • 10 22 2014
1977 KZ650
Called Dynatek.
I think I've seen that purse before That's why I asked.
Last edit: by KZQ.
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 13 Nov 2022 07:14 #876742
  • ShaneDude
  • User is blocked
I hope EVERYONE is having a GREAT weekend!!!!
About to dither with the bike yet again. The throttle cables arent properly set after taking the carbs off and putting them back.
After that, meeting a friend for a ride. Enjoy!!!
77 KZ650 FIXED!!! Wooo Hooo: Cold Pipes, Coil, Carb Story. 13 Nov 2022 07:18 #876743
  • Warren3200gt
Make sure you put em back correct with the open cable  to airbox side and close cable to the engine side
  • Page:
  • 1
  • 2
