  • Page:
  • 1
  • 2
Swingarm brace aluminum extrusion 09 May 2021 03:14 #848246
  • 750 R1
  • 750 R1's Avatar Topic Author
  • Thank you received: 394
Would anyone here have any idea where i could source this type of Aluminium  extrusion ?
Last edit: by 750 R1.
Swingarm brace aluminum extrusion 09 May 2021 07:36 #848257
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
Swingarm brace aluminum extrusion 09 May 2021 15:27 #848270
  • 750 R1
www.mcmaster.com/aluminum-extrusions/
www.brunnerent.com/Tools/Portfolio/front...isplay=0&iPageView=0
www.onlinemetals.com/en/buy/aluminum-rec...be-6063-t52-extruded
Thanks for the links but I've already searched just about every catalogue I could find, I've come here as a last resort, I'm specifically after the very same extrusion in the picture I posted. I've seen it used on many swingarms but am struggling to find it....
Swingarm brace aluminum extrusion 09 May 2021 16:43 #848272
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
Check here. They might be able to help
www.aluminumsupply.com/
Swingarm brace aluminum extrusion 09 May 2021 19:11 #848280
  • 750 R1
Dose anyone know what this type of extrusion is called ?
Swingarm brace aluminum extrusion 09 May 2021 19:20 #848281
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Are you looking for stock of aluminum extrusion, or are you looking for an extrusion that has been bent and formed into the U-shape of a brace?
My dad's '74 Z1
'00 ZRX1100
Swingarm brace aluminum extrusion 09 May 2021 19:45 #848282
  • 750 R1
I'm looking for stock, I'll bend it myself, that picture I posted is from Webike and they want 303USD for what you see.  I just got off the phone to a major supplier here and they told me that it was probably a custom order, to use 6063 or 6060 T5, so I might just buy some 20mmx20mmx3mm radiused tube and mill a .5mm section out of it, I'm wanting that look. I always manage to make everything harder than it needs to be...!!!
japan.webike.net/products/3461382.html
Swingarm brace aluminum extrusion 09 May 2021 20:46 #848285
  • DOHC
  • DOHC's Avatar
I see.  You want that outside detail.  I would have thought that would be possible to find, but poking around the web it does look like it's a bit of a needle in a haystack.  Everything seems to be either plain square extrusions, 80/20 type functional shapes, or weird window trim.  It may be the case that someone somewhere has some stock of that, but I think you're right that it would probably take less time to machine plain square tubing yourself.
I can't help you with alloy choice, other than to say that 6061 does not bend well in a sheet metal brake.  The notes on the extrusions in the McMaster catalog say that 6063 and 6060 are both "easier to form than multipurpose 6061".
Good luck.
My dad's '74 Z1
'00 ZRX1100
Swingarm brace aluminum extrusion 09 May 2021 22:16 #848287
  • 750 R1
Good luck.
Yes, I thought i would be able to find it too. I know a guy that has a company that specialises in aerospace components, i'm going to ask him before I try and make it myself.
I like the way the brace looks with the detail....
Swingarm brace aluminum extrusion 10 May 2021 12:11 #848307
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
The early GSXRs used a tube profile like that. I don't know if it would be cheaper to cut up a frame to get the tube but its an option. sub-frame tubes are 20 x 25, main down tubes are 27 x 30. this is a proprietary alloy similar to 7005.
Last edit: by DoctoRot.
Swingarm brace aluminum extrusion 10 May 2021 15:03 #848308
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
Probably doesn't have the look your after, but what about Chrome Molly tubing?
That is what was used on my swingarm to brace it:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Swingarm brace aluminum extrusion 10 May 2021 15:03 #848309
  • 750 R1
Funny you should say that, I actually have a 1988 GSXR1100J  Frame {last of the slabby's}, I won't be cutting it up though, they are starting to fetch good money....
  • Page:
  • 1
  • 2
