  • Page:
  • 1
Help ID 3 wheels please? 05 May 2021 20:21 #848067
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
  • Thank you received: 583
Wheel 1.Only marking is an 'M' inside a circle.  Bearing holders are removable.  Paper taped to tire reads "1976 KZ900".  Morris Mag?
Wheel 2.'Kawasaki' is cast in.
Wheel 3.'Kawasaki' is cast in.
Thank You.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE. Reason: Better detail pic
Help ID 3 wheels please? 05 May 2021 20:29 #848068
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
Wheel 1 is a 1976 Kz900 LTD Morris front. Wheel 2 ? Z1R. Wheel 3 appears the be a 1977-80 rear LTD Enkei mag.
The following user(s) said Thank You: slmjim+Z1BEBE
Last edit: by Mikaw.
Help ID 3 wheels please? 06 May 2021 06:21 #848078
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 494
I agree with 1 and 3.
It looks like #2 is a 19" wheel, which would make it a matching set with #3.  I believe the 77-80 LTD should have Enkei Kawasaki mags, 19" front and 16" rear.  The '79-'80 MkII and '80 Z1R also had 19" front Enkei Kawasaki mags which I think were basically the same.
My dad's '74 Z1
'00 ZRX1100
Help ID 3 wheels please? 06 May 2021 07:05 #848081
  • Mikaw
  • Mikaw's Avatar
DOHC, you might be right on #2. What thru me off was the valve stem location. On my 1978 Kz1000 LTD rear wheel the valve stem is equal distance from the spokes. I assumed the front would be the same, until I looked thru photos and found one of my front wheel. The valve stem is offset toward one spoke. I’m thinking DOHC is correct and #2 is the front match to #3
  • Page:
  • 1
