  • Page:
  • 1
FJR woes 08 Mar 2021 14:59 #844589
  • TexasKZ
  • TexasKZ's Avatar Topic Author
  • Thank you received: 2051
Well, it looks like the transition from a five-speed to a six-speed transmission has not gone well. I have been considering an FJR pretty seriously, but I am very disappointed at Yamaha’s solution.
www.asphaltandrubber.com/recall/yamaha-fjr1300-2nd-gear-recall/
FJR woes 09 Mar 2021 05:30 #844603
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 376
I have a 2016 FJR and have already had this repair done. All is well...
FJRs are great touring bikes.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
FJR woes 09 Mar 2021 06:25 #844605
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2672
I'm confused. What's wrong with Yamaha's solution?
FJR woes 09 Mar 2021 06:54 #844607
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
I was riding my 41 knucklehead, I turned left on a country road, a shift fork broke and the tranny went into two gears locking the tranny and rear wheel.
I was going about 35 mph when this happened, it was quite exciting, I kept the bike upright, my heat was beating pretty good when I stopped.
FJR woes 09 Mar 2021 15:07 #844633
  • TexasKZ
Nessism wrote: I'm confused. What's wrong with Yamaha's solution?
According to he article, Yamaha is reflashing the ecu and replacing axles. Not a word about replacing the weak gears.
FJR woes 09 Mar 2021 15:13 #844636
  • ThatGPzGuy
I was sent a pic of my FJR with the engine out and completely dissembled. Pretty sure it is more involved than ECU and axles.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: by ThatGPzGuy.
FJR woes 10 Mar 2021 04:53 #844667
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
From then little I have read here it certainly appears Yamaha is addressing the trans issue head on. They even give a time estimate of repairs which may, or may not be completely accurate. BMW did not give a time estimate on the trans repair work on the K1600. How long the problem has existed is something else again, but it has been identified and correction process initiated. Saying a repair is 54 minutes long is a bit odd. Why not just say an hour?
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Page:
  • 1
