  • Page:
  • 1
  • 2
1977 KZ900 A5 01 Mar 2020 15:40 #820132
  • KEVDOGG1
  • KEVDOGG1's Avatar Topic Author
  • Thank you received: 0
Wondering what the a5 means just got bike couple weeks ago dont know an 48927_1361131807428864_5129708079901835264_n.jpg[/attachment]
1977 KZ900 A5 01 Mar 2020 19:38 #820143
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
5th 900cc
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1977 KZ900 A5 02 Mar 2020 04:27 #820150
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
As I under stand it
KZ = street model
900 = engine size approximately
A or whatever the letter = the specific model (Standard, LTD, GPz, etc)
4 or whatever the number = which year of production of that specific model
A1 would be the first year, A2 the second year and so on, so you have the fifth year of production of the 900 A.
A very nice looking one, by the way.
Last edit: by TexasKZ.
1977 KZ900 A5 02 Mar 2020 07:55 #820158
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
Nice Looking Motorcycle. It should have a drum brake on it. It was a first 1/2 yr. 1977 KZ900. Late 77 had the KZ1000 with a disc brake rear. My old brain is rusty. My 1st car tire conversion bike was a 1977 KZ900. I sold that title only in 1985
1977 KZ900 A5 02 Mar 2020 17:01 #820173
  • urankjj
  • urankjj's Avatar
  • Thank you received: 201
A bit confusing. If it's the fifth yr of production and it's a 77, then the first yr would be a 72-900, correct. Mine is a very early, ( if not one of the earliest left) 77-kz 1000 A1. Vin # KZT00A000283, engine # KZT00AE000295, and it has a rear disk brake. Hope this can help...?
1977 KZ900 A5 02 Mar 2020 20:05 #820180
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
1973 Z1 900 = 1st year
1974 Z1A 900 = 2nd year
1975 Z1B 900 = 3rd year
1976 KZ 900 A4 = 4th year
1977 KZ 900 A5 = 5th year
urankjj you have the first year 1000 thus the "A1".
The only 900 with rear disc was the unicorn 1976 KZ900 LTD, which also had the first factory dual front disc.
The following user(s) said Thank You: BCScott
1977 KZ900 A5 04 Mar 2020 07:55 #820274
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
A few KZ900's were made in 77,
1977 KZ900-A5 Z1F-510341 to Z1F-515578 (5237) - USA
1977 KZ1000-A1 KZT00A-000001 to KZT00A-026623 (26623)- Japan
1977 KZ1000-A1 KZT00A-500001 to KZT00A-507026 (7026) - USA
1977 KZ1000-LTDKZTOOB-500001 - LTDKZTOOB507530 (7530)
77 Total=46416
The following user(s) said Thank You: Mikaw, BCScott, urankjj
1977 KZ900 A5 04 Mar 2020 08:22 #820276
  • Mikaw
  • Mikaw's Avatar
73z1 wrote: A few KZ900's were made in 77,
While we’re on the 1977 subject, I could use help identifying a frame I got in a parts lot purchase. The year is worn off the tag, the tag and frame numbers match, appears to be in the correct range to be a 1977 kz900 A5. Z1F-5143XX. But see photo of what appears to be a rear MC mount.
1977 KZ900 A5 04 Mar 2020 09:45 #820283
  • 73z1
  • 73z1's Avatar
>>>>>"While we’re on the 1977 subject, I could use help identifying a frame I got in a parts lot purchase. The year is worn off the tag, the tag and frame numbers match, appears to be in the correct range to be a 1977 kz900 A5. Z1F-5143XX. But see photo of what appears to be a rear MC mount."
I checked my A5 photos, none have this bracket.
Someone added the bracket or replacement frame.
1977 KZ900 A5 04 Mar 2020 10:17 #820287
  • Mikaw
  • Mikaw's Avatar
73z1 wrote: >>>>>"While we’re on the 1977 subject, I could use help identifying a frame I got in a parts lot purchase. The year is worn off the tag, the tag and frame numbers match, appears to be in the correct range to be a 1977 kz900 A5. Z1F-5143XX. But see photo of what appears to be a rear MC mount."
Replacement?
1977 KZ900 A5 04 Mar 2020 11:26 #820290
  • 73z1
  • 73z1's Avatar
Your tag has some wear, my guess is 8 98
1977 KZ900 A5 04 Mar 2020 14:22 #820305
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
It can't be a Z1 frame with 8 98. I suspect it's Aug 75 or Aug 76 but I lean towards '76 because of the relatively high serial number.
  • Page:
  • 1
  • 2
