  • Page:
  • 1
Adding saddle bags to my '81 650 csr 18 Nov 2018 06:03 #793889
  • jljim
  • jljim's Avatar Topic Author
  • Thank you received: 8
Wanting to add some luggage capacity to my '81 650 CSR. Does any one have pics or tried a particular brand of saddle bags that fit ? I was looking at the TourMaster line and a couple others, hard to choose without trying them on the bike.
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
1979 Puch Maxi ( sold to buy the 650 )
1987 GL1200 Interstate
1986 GL1200 Aspencade (parts donor)
Adding saddle bags to my '81 650 csr 18 Nov 2018 06:39 #793890
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2599
Links to what you're looking at?
Adding saddle bags to my '81 650 csr 18 Nov 2018 07:17 #793892
  • jljim
TourMaster Select or TourMaster Elite from Revzilla.
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Adding saddle bags to my '81 650 csr 19 Nov 2018 07:00 #793956
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1620
I've been wanting to add saddlebags to my 650-CSR, but it seems like the turn signals are going to be in the way. I use a Cortech tail bag that I like, but never got around to getting the saddlebags or moving the turn signals.
Luggage rack. If you're interested in getting a luggage rack, there are universal fit racks from back in the day on ebbaayy. I've had one on my csr for several years. it was listed for a KZ550, but the type was used on many models. Kaws, Hondas, Suzuki, Yamaha. most sellers just list them according to the bike they were on. CB750. GS850. XS650. KZ1000. etc. Aschco & KG are a couple of brands.
Last edit: by martin_csr.
Adding saddle bags to my '81 650 csr 24 Nov 2018 07:27 #794162
  • jljim
My bike has a KG rack adapted to the back, pretty decent fit. Yes , the turn signals would probably be in the way but the leads have a couple extra inches of wire . I'll look a little more at the tail bags, might work easier than the saddle bags. 49 degs and a little sun yesterday, put 70 miles on the bike just cruising the back roads :)
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Adding saddle bags to my '81 650 csr 25 Nov 2018 05:16 #794192
  • martin_csr
A simple solution for the turn signals that might work would be to move them to a rearward hole on the luggage rack. maybe go with shorter stems or different signals.
Adding saddle bags to my '81 650 csr 16 Dec 2018 14:41 #795249
  • rstnick
  • rstnick's Avatar
  • Thank you received: 372
I bought a CSR many years back that had a set of saddle bags on it.
Will look for some pictures.
May help.
Very similar to the set I had on my 650C2, which I could probably let go now:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
Adding saddle bags to my '81 650 csr 16 Dec 2018 15:15 #795252
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 511
TOO BAD, i HAVE THESE OLD BAGS SITTING? Gee sorry PC world i used caps wtf? I like caps! cause I can't see ! i'm 60!
BUt I tried selling these for 3 years? No one want to make brackets? Or modify and use them?
Things are not like they were 30-20 years ago?
Last edit: by z1kzonly.
Adding saddle bags to my '81 650 csr 29 Dec 2018 11:30 #795877
  • jljim
I got a set of TourMaster bags off eBay and a luggage rack/sissy bar that fits the bike. They were used in decent shape, Cruiser III in the medium size. The bags will set pretty well with the tail lights repositioned on the luggage rack a little farther back than the stock mounts were. The seat won't open on the hinges with the new rack in place. I took the pins out and use the lock on the left side and the rear pin inserted on the right side after the seat's in place. A little stainless wire loop around the verticle frame bar holds it in place. Looking at a couple tail bags to hang on the back and I should be ready to go. If I need more space, I'll just go shopping for a Voyager.......
1981 KZ650 CSR
1985 ZN 1100 LTD
1982 GS1100GL
Adding saddle bags to my '81 650 csr 04 Jul 2020 11:00 #829762
  • Joe De
  • Joe De's Avatar
  • Thank you received: 0
HELLO,
I’M IN ALL CAPS FOR YOU. DO YOU STILL HAVE THE SIDE BAGS? I’M ALWAYS UP FOR A PROJECT! I COULD DRIVE UP FROM RI TO GET THEM.
THANK YOU,
JOE
78 KZ650C
  • Page:
  • 1
