E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 08:48 #845913
  • BCScott
  • BCScott's Avatar
  • Thank you received: 53
Was the steering damper ever a factory/dealer upgrade?
Back in the saddle and loving it! KZ1000A1
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 09:29 #845917
  • SWest
  • SWest's Avatar
  • Moderator
  • Thank you received: 2024
Yes the lower tree was setup for it. The frame gusset was stronger but in 76 they added another one on other side and put reflectors on them. They're very weak so one needs to be beefed up and a hole drilled or clamps must be used.
Opinions expressed by me do not reflect those of the the staff or members
The following user(s) said Thank You: BCScott
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 09:34 #845919
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 648
Allen head cap bolt. Most fasteners are wrong. Drilled rotors. Short turn signal stems. Wrong tires. Wrong plug boots. Wrong brake/clutch levers. Tire sticker on the rear inner fender? No helmet sticker on the frame. Rectangular tire sticker on the rear duck tail. Repop rear fender(the rear wire harness in not routed through the rubber coated bracket. Something looks wrong with a black terminal cap on the positive battery terminal. Lack of attention to detail. The front brake hose grommets are distorted, the tachometer cable needs to be between the dual front brake hoses. Zip tie on front fork station? Ignition coils are aftermarket. Rear hub painted black.front RH upper motor mount bolts in backwards. D.I.D rear rim (no rim locks). I don’t see the red infill on the run/stop/run switch. Actually it’s the wrong RH control. Wrong wire clips at spark plugs, Z1 were rubber coated.
Edit: I agree with HRM, it’s a rebuild, not restoration. It’s pretty, but so much wrong. But it’s the buyer that needs to do their research. I don’t like the way it presented. It’s far from a museum nut and bolt restoration. That being said why did it take 2 years. You could buy all those parts and have them in less than a month. About two to three weeks to bolt it together. 2 months tops, total for parts order shipping and build. Sad someone will pay to much money for it.
Last edit: by Mikaw.
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 10:34 #845923
  • Mikaw
  • Mikaw's Avatar
Might run better if the fuel line was connected. LoL
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 10:37 #845925
  • Mikaw
  • Mikaw's Avatar
Front foot pegs are aftermarket. Wrong spring clamps on the air box breather hose and carb bowl over flows
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 10:56 #845929
  • Mikaw
  • Mikaw's Avatar
Rear Brake switch is aftermarket. Look were the carb bowl overflow hose rubber band is. It’s wrapped around the frame and not on the upper rear engine mount spacer. I know if I paid $650 for carb rebuild I’d like $25 worth of choke spools installed.
The more i look the more it upsets me about how it’s presented. It’s a bunch of aftermarket repop junk.
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 15:36 #845950
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 68
The zip tie on the front fork is to check sag and how much stroke is being used when riding to set compression and rebound. Sort of odd to see that on forks that can't really be adjusted...
If nothing else, the bodywork looks good.
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 15:55 #845955
  • krazee1
  • krazee1's Avatar
  • Thank you received: 129
In addition to what's been mentioned, the front brake hose is routed through the throttle cable loop,  the funky long acorn nuts on the exhaust flanges, and it appears in the close up on the right side of the front wheel that the gap of the axle clamp is in the front.
I knew you guys would get a kick out of it,  definitely not described accurately!  Maybe it can be used as a guide as to how NOT to "restore" a Z1A.
Mike
1974 Z1A (disassembled)
1976 KZ900B LTD (SOLD!) it's in GOOD Hands!
1978 KZ1000 LTD
1976 KZ900B LTD pile O parts!
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 16:17 #845956
  • SWest
  • SWest's Avatar
  • Moderator
Click the report button.
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 01 Apr 2021 16:26 #845957
  • Mikaw
  • Mikaw's Avatar
Mike
It would be a great advertisement for Z1 Parts. Except for the frame, Engine (suspect), carbs, lower forks, and front and rear hubs, it’s a poster child for the aftermarket world... The aftermarket has it place, but not in being pawned off as a 2 year Museum nut and botl restoration.
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 06 Apr 2021 18:35 #846302
  • krazee1
  • krazee1's Avatar
Another 74,  looks pretty legit?
1974 Kawasaki Z1 900
Completed
1978 KZ1000 LTD
E-Bay / Craig's List Thread. Post 'em Here!!!!!!!! 06 Apr 2021 19:14 #846303
  • Mikaw
  • Mikaw's Avatar
Something phisy here. I thought this sold for $315.00
Dragbike KZ Z1 73-80 Chrome Gauge Covers Set Vintage 900 1000 Kawasaki Nice! NR!
Completed
